: Power attn Motor!!!!
06-23-11, 02:43 AM
can someone please help me. i need to replace my power attn motor and the actual attn itself but i cant find the dam motor ive looked right where it comes out of the hood but i cant seem to find it. any info would be nice and a picture of it would be even better, thanks in advance.
06-23-11, 02:54 AM
It's towards the bottom of the fender, a small cylinder-shaped thing just behind the wheel well.
06-23-11, 10:30 PM
i can hear it on and running but it sounds like its stuck. the only way to make it stop is to pull the fuse. and i looked and i dont see anything but like i said i can hear it.
06-24-11, 12:12 AM
Likely the cable that runs the antenna has snapped. That's why the motor keeps running. You may have better luck seeing it from underneath the car.
cadillac kevin
06-24-11, 12:22 AM
is it possible to replace that cable? (my antenna goes down manually to about an inch high, and the motor keep working until I unplug it)
06-24-11, 02:01 PM
Yes. You must disassemble the antenna and motor assembly. Many people use plastic wire similar to that found on a weed wacker.
