: Surface Rust - Wheel Hubs - How to Remove? PICS INSIDE!
xRUSTYx
06-19-11, 11:48 AM
Hey Guys ....
We've had some hard hard rains here the last few days, so the car has sat (I don't really drive the CTS-V in the rain, we stick to our Jeep). Anyways, went out yesterday and noticed surface rust on ALL 4 wheel hubs? See Pictures ... Has anyone else ever had this happen to their CTS or -V ? Very strange, I've never had this happen to any other vehicle ....
Is there a product I can use to fully remove it? And would it be best to pain the hubs with a Rust Proof paint/adhesive?
Here are some pics (coming in 3 more posts -- I need to have 5 to post links/pictures)
PICTURES:
http://i119.photobucket.com/albums/o148/xcashmerex/2011%20CTS-V/Hub2.jpg
http://i119.photobucket.com/albums/o148/xcashmerex/2011%20CTS-V/Hub1.jpg
http://i119.photobucket.com/albums/o148/xcashmerex/2011%20CTS-V/Hub3.jpg
xRUSTYx
06-19-11, 12:10 PM
pics added :)
neuronbob
06-19-11, 12:18 PM
Happens to my car too. Just drive it, it goes away after the first brake application. Happens on cars other than the V as well.
xRUSTYx
06-19-11, 12:23 PM
neuron ...
I'm not talking about the rotor ...
Look at the hub ... The hub won't rub off like the rotors - My rotors have rusted on every single car I've owned :) haha
xRUSTYx
06-19-11, 12:27 PM
Here's a picture with the outline:
David Nicholas
06-19-11, 12:38 PM
The hub will develop a complete coat of surface rust if left to its own devices. (Look around at other cars). Some paint them, some try to keep them dry. Yours looks like a very early case that will clean up with light steel wool and be good as new. If you occassionally wipe them with WD-40 or something similar after exposure to water, you can generally keep them rust free. (you need, of course, to keep any protectant of the rotor surface...)
gonfishin
06-19-11, 12:54 PM
Yes good advise from Dave Nichols. One option would be to paint with a high temp paint then apply some sort of protectant.
I am considering doing this myself.
xRUSTYx
06-19-11, 02:50 PM
well ...
Just went at it with Steel Wool, a cup of water, and some WD40 ... Got all the rust off, but underneathe, it had already turned a blacking/gray color. Atleast its better than the rust color!
I'm probably going to paint with a high temp engine enamel, and if there is even a *chance* of rain, keep her garaged.
Thanks for the suggestion David & cbl .... what type of protectant would you use over the paint?
neuronbob
06-19-11, 07:41 PM
neuron ...
My bad. The rotor rust comes up on such a regular basis in this forum that I only half-looked. :D
High-temp enamel is your answer and I've thought about doing the same to mine.
M5eater
06-19-11, 08:31 PM
you could have them zinc coated and/or buy zinc coated rotors. Painting will work for the Hubs, but the veins will continue to rust into nothing. Zinc will take care of *all* of that. I can't believe they're not zinc plated from the factory.. my 10 year old B5 S4 had the factory rear rotors and 0 rust .
Domsz06
06-19-11, 09:19 PM
I had the same issue and just painted them like others have said. No big deal.
xRUSTYx
06-20-11, 10:31 PM
for those that have painted it ... mind sharing pics?
Tedboss1
06-21-11, 10:06 AM
Have look at another thread on the same topic:
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/180185-rust-wheels-any-suggestions-similar-problems.html
pmsteinm
06-21-11, 01:55 PM
Those of you that have rust on your rotor hubs: Do you use any kind of wheel cleaner? I thought I read a while back that some wheel cleaners will take the coating off the hub which then allows rust. I haven't had the rotor hats rust on either the V1 or V2, or my wife's car either.
My brake rotor surfaces rust like above when they get rained on or I wash the car, but after a few stops they are clean.
Torxila
06-21-11, 03:35 PM
I also had discoloration of hubs from certain wheel cleaners. On GM light grey hubs (TBSS, C5, C6)they stained turned hubs dark grey/balck almost. I stopped using spray on wheel cleaners.
I switched to Baer Zinc Coated Eridispeed rotors on my C5Z06 and C6-Z51/vert, and had no problems with or without any claeaners.
To be 100% sure, ZINC plate them.
Regards,
George
Domsz06
06-21-11, 03:46 PM
I thought I had a thread, but here are my pics....
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01078.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01080.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01082.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01084.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01091.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01096.jpg
now my wheels are black....
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01104.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01111.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01116.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01121.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01119.jpg'
You can see how it looks here with the z06 front rim.
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/ba434101.jpg
http://i161.photobucket.com/albums/t216/domsz06/CTS-V/DSC01334.jpg
xRUSTYx
06-21-11, 04:21 PM
My car only had 400 miles on her when I noticed the rusting hats ... No wheel cleaner ever ...
xRUSTYx
06-21-11, 04:22 PM
Thanks for the Pics Doms .... that really helps! Looks great with Black wheels!
Kluch
08-23-11, 12:50 PM
My hubs have rusted pretty good. I took it to dealer and was told this is normal. Nothing could be done. I hate these rusty hubs so much (so ugly) so I searched the forum. Found this post, but I don't have the equipment, time, or frankly the ability to do this myself. I'd need to pay someone to do it for me. That said, I went to a local body shop but they wouldn't want to paint my rotors. Should I take it back to the dealer or the body shop and bring a pack of SOS pads and a copy of this thread? I undertand why someone wouldn't want to paint my rotors (liability) but I feel like this is an issue that dealers and body shops would see on a regular basis, no? Suggestions would be appreciated. I'm going back to dealer to have my clicking wheels addressed again, so it wouldn't be a special trip. Thanks in advance.
cdog533
08-23-11, 02:17 PM
I would sand them, steel wool them, get the rust off... Then apply some Armor All Wheel Protectant or something similar. It's just a temporary fix, as this might need to be repeated every year or so.
As for wheel cleaners, don't use the heavy acid based ones. Use P21S or just a simple multi-purpose cleaner for the wheels. You don't need anything strong. The acid ones may contribute to rust on the hub.
M5eater
08-23-11, 06:46 PM
where do you live? I'm @ 4,000 miles, and I have 0 rust. However, I can say they they're definitally *not* coated, Zinc is a visually shiny metal. I'm sure considering the amount of solvents in wheel-cleaner though it doesn't slow the process of oxidation however.
