View Full Version : Something I heard about the a/c bolts
7.0,hellyeah
10-14-04, 10:00 PM
I heard in another thread that if you remove the a/c compressor assmebly on a 425 that it will cause a vacuum leak where the bolts go in. Is that really true. It seems absurd to me but with all of those vacuum lines I figure anything is possible. I removed my a/c and It doesn't seem like it has been a problem.
Dead Sled
10-14-04, 11:35 PM
it is possible that the mounting holes aren't blind (go all the way throu into the intake plenum or runners) but if they are you can just plug them with a short bolt or an allen head plug. the vaccum leak would come from the unfilled hole left be the mounting bolt
mastertech
10-15-04, 09:19 AM
The mounting holes are blind, and no vacuum leak will occur with removal of the ac compressor...you should be all set!
mastertech
10-15-04, 09:23 AM
In fact, let me know if you need any a/c components for your 425. I have an 80 Deville with a 425 from a '78, but I used the radial type compressor from my car and switched over the brackets. My engine broke a rod, so I'm parting it out. You can PM me, the air blows ice cold (until my motor DIED!). i'LL HOOK YOU UP CHEAP!
7.0,hellyeah
10-18-04, 07:55 PM
No thanks, I took it off not only because I wanted the extra power that comes along with taking off the a/c, but because my climate controlls dont even work. :halo:
abcdefg
10-25-04, 10:03 PM
removing a pulley from the belt line really doesnt give you much more hp. If a 1/10th hp 3800rpm electric motor can spin the pulley around on my A/C without loading down the motor too bad...
davesdeville
10-26-04, 12:46 AM
Sure saves some weight though.
caddydaddy
10-26-04, 08:18 AM
That's not true! It might be different on the 368, but on the 425, at least one of the bolts goes into the intake plenum. I removed the A/C compressor from my 425 a few years ago, and it would stall going into gear. I quickly found out that there was a hole in the intake! I replaced the bolt, and the car ran fine.
