Ed @Lingenfelter
10-14-04, 05:44 PM
Here are some details on our Cadillac CTSV 427 N/A package. This is the same combination that we used in the Car and Driver shootout. If you saw it on TV, then you are aware of the smoothness, and reliability of this combination.
The package includes:
Engine removal, inspection, and dissassembly
Block machining and machining for sleeves
Custom aluminum block preperation
Darton modular sleeve assemblies
ARP 8740 premium grade head studs
Lingenfelter CNC ported stage III cylinder heads
Stainless steel 2.100" hollow stem intake valves
Stainless steel 1.57" hollow stem sodium filled exhaust valves
Comp Cams double valve springs and titanium retainers
3 angle valve job, checking of spring tensions and heights
Custom designed Lingenfelter hydraulic roller camshaft
1.85:1 roller rocker arms and HD push rods
Cloyes HD timing chain set
Lingenfelter HD rocker arm stands
Custom forged aluminum pistons - 11.0:1 compression
Custom forged steel crankshaft - 4.00" stroke
Billet steel connecting rods - 6.125" long
Computer balanced rotating assembly
Re-assembly and blueprinting of the engine
Engine dyno test including 1 hour break-in procedure
Stainless steel exhaust by Corsa performance
Lingenfelter cold air intake system
Lingenfelter engine oil cooler package
FAST composite intake manifold, 90MM throttle body, and properly sized fuel injectors
ASP underdrive pulley & Goodyear belt
Professional installation, testing, and tuning
Chassis dyno test after installation
LPE 2yr/24000 mile warranty
Package price: $24,995.00
510 HP @ 6000 RPM
530 Ft.Lbs @ 4600
Honestly, when you stand next to one of these at idle, you would swear it was a stock car with an exhaust system on it!
Let me know if I can answer any questions,
Ed
510 HP @ 6000 RPM
530 Ft.Lbs @ 4600
Ed
