: Caddy Top Question.
BHogg
06-06-11, 10:48 AM
I'm just a proud owner of a 69 Caddy Deville Convertible.Going to add to my Dukes of Hazzard Collection.
A good friend has got the pump going but it needs oil.
1) What kind of oil and there is a plug in the bottom??
2) Do we need to take the entire pump out from back seat(not fun) or can we just add oil to pump from bottom.
Thanks
Rob
Ontario,Canada
69Chateau
06-06-11, 12:28 PM
Regular ATF transmission fluid goes in the pump. There is a drain plug on the reservoir but its not "on the bottom". Its on the end above the middle of the reservoir. Its a rubber plug that fits into a filler hole. The instructions for filling and bleeding the reservoir are pretty straight forward, but, they require fabricating a special "filler plug" if you want to follow the instructions verbatim. If there is no fluid in the system (lines, cylinders, reservoir), you might want to follow those instructions because more fluid will be required to raise/lower the top than the reservoir will be able to initially supply.
BHogg
06-06-11, 01:17 PM
thanks for the info.
Where do I find the instructions?
thanks
Rob
jayoldschool
06-06-11, 08:19 PM
In the factory service manual, and the Fisher Body manual. If I can find it, I will scan it.
CADforce69
06-07-11, 07:09 PM
I think this is what you need ;)
http://s4.postimage.org/c3fqj5d9s/Folding_top.jpg (http://www.postimage.org/)
image hosting service (http://www.postimage.org/)
http://s4.postimage.org/507rsgiuo/Folding_top1.jpg (http://www.postimage.org/)
image upload (http://www.postimage.org/)
jayoldschool
06-07-11, 07:46 PM
Thanks, cadforce. Rob, where in ON? I'm just east of Ottawa.
robb257731
06-09-11, 11:16 AM
Hey Jay, has it been as stinking hot out your way as it is in Hamilgrad?
jayoldschool
06-09-11, 12:47 PM
I feel like a lobster. No AC where I work...
BHogg
06-13-11, 07:34 AM
If anyone has actually filled the pump, what size hose is needed for filler?
Thanks
Rob
