View Full Version : CTS Model Year Feature Changes - Comprehensive List
M.Dubb1969
06-05-11, 06:18 PM
I'm new here and I just bought a used 2009 CTS DI PDQ (Premium) FE2 RWD. The build date was August '08. I have every available option except Block Heater, AWD and/or FE3. When I was looking for it, I had to do a lot of research to figure out which model years had the options that I wanted. I think it would be helpful to those in the market for a used CTS to have a comprehensive list of which features have been added or de-contented based on the model year and build date.
For example, I wanted Bluetooth so I ruled out 2008 models, but now I understand that some late-build 2008's have it. I also understand that maybe some 2009 models built after mine don't have options that I have.
I have lighted front footwells but not in the rear. Did the 2008 models have rear footwell lighting as well?
What is the 2009 model missing that 2008's have?
Same goes for 2009 to 2010, etc.
Please list build dates if you have them. Thanks!
jghiller
06-06-11, 04:40 AM
Yes 2008 has rear lighted footwells, along with front footwells, gear shift, doors(4) and around wood trim. Not sure about rainsense wipers which 08s have and of course the heated washer which went away in 09 I think but can easily be replaced.
M.Dubb1969
06-06-11, 10:09 AM
Thanks for the reply. Looks like we can add rear footwells to the list of de-contented items on 2008 to 2009. My early-build 2009 does have all of the other lighting mentioned as well as rain sense wipers. It even has the lighting on the rear door handles. Strange that they left that and took away rear footwell lighting.
C "T" ess
06-06-11, 11:33 AM
what you are asking for should be easily found by using the search function. Each model year there has been a discussion on what's new and what's been deleted. To list all of that information in one spot given the model year breaks and changes along the way would probably be a herculean task. enjoy your car.
M.Dubb1969
06-06-11, 12:20 PM
C "T" ess,
I have read many of your posts. I enjoy them, and am thankful that you are such an active member. That being said, I have diligently searched this forum and others and strongly dispute how "easy" it is to get this info. For one, the search functions are not easily refined on this forum. I get scores of almost completely irrelevant posts including more posts on models other than the CTS. Maybe I'm doing something wrong, but is there a way to refine the search results just to the CTS model? Secondly, I wish the members did a better job of using more descriptive titles. Take mine for example. Type in "CTS model year changes" or "CTS Features" and you will get it. Too many posts use ambiguous titles. I wish people kept this in mind when posting.
A herculean task it may be, but we have a lot of members here. With helpful contributions from just a fraction of them, it can "easily" be accomplished. If the topic interests you, please post. If not, please refrain from dampening the enthusiasm of those that do.
I think this will help those in the market for a used CTS. I wish a unified list was available when I was doing my due diligence. I just want to help and contribute.
RAB
06-06-11, 11:49 PM
This thread convinced me it's time to put some reference info together about major RPO's, options & packages on the 2008+ CTS Sedan together with model-year feature changes. Apologies in advance for any items I may have missed.
Info provided here pertains specifically to major features / major feature changes to the 2nd Gen CTS 'Sedan', m-y's 2008 to 2011. Info for the CTS-V is not included. Neither are the "appearance packages" for the 2010 & 2011 CTS. Too soon to talk about the 2012 CTS, with production not yet begun as of this date.
2008 Cadillac CTS (all new 2nd Gen CTS Sedan)
- Production Start: June-July 2007
- Manufacturing Location: Lansing Grand River Assembly, Lansing, Mich.
*Engine (base, 3.6L): RPO code LY7 3.6L V6 VVT SFI with 263 horsepower @ 6200 rpm and 253 lb.-ft. of torque @ 3100 rpm
>>Engine (optional, 3.6L DI): RPO code LLT 3.6L V6 VVT SIDI with 304 horsepower @ 6400 rpm and 273 lb.-ft. of torque @ 5200 rpm
*Transmission (base, manual): RPO Code MN6 Aisin AY6 Transmission, 6-speed Manual
>>Transmission (optional, auto): RPO code MXO 6L50 Hydra-Matic Transmission, 6-speed automatic for RWD (vehicle badge = CTS)
>>Transmission (optional, auto): RPO code MX7 6L50 Hydra-Matic Transmission, 6-speed automatic for AWD (vehicle badge = CTS4)
*Suspension (base, soft-FE1): RPO code FE1 - Comfort Suspension, 4-wheel independent - Includes 17" wheels w/ all-season tires and (JE5) standard braking system
>>Suspension (optional, sport-FE2): RPO code FE2 - Sport Suspension, 4-wheel independent - Includes 18" painted wheels w/ all-season tires and (J55) performance braking system (AWD config only; on FE2 RWD config JE5 standard braking system is applied). FE2 suspension part of Y42 18" All-Season Tire Performance Package.
>>Suspension (optional, performance-FE3): RPO code FE3 - Performance Handling Suspension, 4-wheel independent - Includes 18" polished (P63) wheels w/ summer performance tires, automatic rear-level control and (J55) performance braking system. FE3 suspension part of Y43 18" Summer Tire Performance Package.
Individual extra-cost Options/Packages:
6DP69 - CTS 3.6L SIDI.. vehicle model code includes 304 HP (LLT) 3.6L V6 VVT SIDI high-feature engine
B19 - Wood Trim Package.. Sapele wood on instrument panel, center console and door trim
B20 - Wood Trim Package.. Sapele wood on steering wheel and shift knob
C3U - Sunroof.. Power, Ultraview
MX0 - 6 Speed Automatic Transmission (RWD)
MX7 - 6 Speed Automatic Transmission (AWD)
P63 - Wheels, 18" x 8".. Aluminum with high-polished finish - Standard wheel on Y43 (FE3) package; available optionally (at extra charge) when vehicle ordered with Y42 (FE2) Package + LLT engine
UAV - Audio system with HDD-based Navigation, AM/FM stereo, XM Radio capable, CD/DVD/DVD-A/DVD-V player, MP3 playback, Bose 5.1 Cabin Surround Sound 10-speaker system, Radio Data System (RDS), 40GB Hard Drive Device (HDD), USB connector, 3.5mm auxiliary input jack, 8" pop-up hi-def touch screen, Nav/Infotainment Voice Recognition, XM NavTraffic & XM NavWeather capable
U2S - Audio system, AM/FM stereo, XM Radio capable, CD/DVD/DVD-A player, MP3 playback, Bose 5.1 Cabin Surround Sound 10-speaker system, Radio Data System (RDS), 40GB Hard Drive Device (HDD), USB connector, 3.5mm auxiliary input jack
Y40 - Luxury Level One Package (aka Sight & Sound Package in Canada) - Includes in-dash 6-disc CD changer, MP3 playback, theft-deterrent system with audible/visible alarm, Rainsense wipers, interior ambient accent lighting and 17" x 8" machined finish aluminum wheels
Y41 - Luxury Level Two Package (aka Comfort & Convenience Package in Canada) - Includes heated and ventilated front seats, split-folding rear seatbacks, power tilt and telescopic steering column, universal home remote, ultrasonic rear parking assist and keyless access system with remote vehicle starter system
Y42 - 18" All-Season Tire Performance Package - Includes sport suspension (FE2), limited-slip differential, 18" x 8" premium multi-coat painted aluminum wheels, P235/50R18 V-rated all-season tires, fog lights and Xenon High-Intensity Discharge (HID) headlights with adaptive forward lighting system and headlight washers, (performance braking system included with AWD automatic transmission only), (performance cooling system included with automatic transmission only)
Y43 - 18" Summer Tire Performance Package - Includes performance handling suspension (FE3), automatic rear-level control, performance braking system, speed-sensitive steering, limited-slip differential, 18" x 8" high-polished aluminum wheels, P235/55ZR18 Y-rated summer performance tires, fog lights and Xenon High-Intensity Discharge (HID) headlights with adaptive forward lighting system and headlight washers (performance cooling system included with automatic transmission only)
Misc. Info:
1. Bluetooth integration was not available/not included on early to mid-year build 2008 CTS's. Bluetooth was finally introduced on the vehicle beginning with mid-April 2008 CTS production.
2. The 2008 CTS did not get 'active head restraints' (front seats) until late-December 2007 vehicle production. 2008 m-y CTS's built prior to late December 2007 were equipped with non-active head restraints.
3. GM had quality/supply issues with the B20 Wood Trim Package from start of 2008 production (June/July 2007) until approx. October 2007. As a result many early build 2008 CTS's are equipped with the B19 Wood Trim Package but not the B20 Wood Trim Package.
4. Link to RPO code list for 2008 CTS: http://www.cadillacforums.com/forums/2008-cadillac-cts-general-discussion/130777-rpo-codes-2008-cadillac-cts.html
5. 2008 CTS sales brochures:
> USA version (abridged) - http://www.keepandshare.com/doc/2781021/2008-cadillac-cts-brochure-usa-abridged-pdf-april-30-2011-8-52-am-445k?da=y
> Canada version - http://www.keepandshare.com/doc/2781020/2008-cadillac-cts-brochure-canada-pdf-april-30-2011-8-52-am-3-7-meg?da=y
2009 Cadillac CTS
Deletions/Adds/Changes/Misc. Info:
1. Color deletions & adds
2. Deletion of Heated Washer Fluid System (rpo XA7)
3. Factory removal of rear footwell ambient lighting at beginning of m-y production
4. Factory removal of front footwell ambient lighting in late m-y production
5. Reverse tilt-down sideview mirror feature/option removed in vehicle personalization
6. Engine cover changed from original 2008 painted version (silver color) to non-painted all-black version in late m-y production
7. Bluetooth integration offered as standard feature (all CTS equipment iterations)
8. Original 2008 all-black GPS roof antenna replaced with painted 'shark fin' design antenna
9. 2009 CTS sales brochures:
> USA version - http://www.keepandshare.com/doc/2306662/2009-cadillac-cts-brochure-usa-pdf-october-17-2010-1-28-pm-3-8-meg?da=y
> Canada version - http://www.keepandshare.com/doc/2306661/2009-cadillac-cts-brochure-canada-pdf-october-17-2010-1-28-pm-4-2-meg?da=y
2010 Cadillac CTS
2. Deletion of Rainsense Wipers (rpo CE1 in Y40 package) and Headlamp Washer System (rpo CE4 in Y42 & Y43 packages)
3. Deletion of Limited Slip Differential (rpo G80) on Y42 (FE2) Package. [Note: rpo G80 only available with Y43 (FE3) Package]
4. Deletion of (J55) Performance Brakes and (V03) Performance Cooling System on Y42 (FE2) Package combined with AWD. [Note: rpo's J55 & V03 only available with Y43 (FE3) Package]
5. Underhood appearance package deleted as a factory-applied item; made available as an accessory item from dealer
6. Ground-effects design rocker panels added
7. Deletion of rpo code LY7 base engine (3.6L V6 VVT SFI)
8. Addition of rpo code LF1 base engine (3.0L V6 SIDI DOHC VVT)
9. Re-design of optional LLT 3.6L V6 VVT SIDI engine (eg. change from original 2 accessory belt engine design to 1 belt; '07-'09 timing chain issue(s) apparently addressed; fuel economy improvements)
10. Hydra-Matic 6L45 6-speed auto transmission paired with new LF1 3.0L DI engine; Hydra-Matic 6L50 6-speed auto transmission remains paired with LLT 3.6L DI engine
11. Change to style/config of 18" inch wheels on Y42 (FE2) package (i.e. change from original '08/'09 9-spoke wheel to new 14-spoke wheel) - wheel style/config change impacts the package standard (P75) 18" painted wheel as well as the optional (P63) 18" polished wheel
12. Deletion of (P63) high-polished finish 18" x 8" aluminum wheels with (QUR) P235/50ZR18 Y-rated performance summer tires on Y43 (FE3) Package
13. Addition of (PJ2) high-polished finish 19" x 8.5" aluminum wheels with (Q0M) P245/45ZR19 Y-rated performance summer tires on Y43 (FE3) Package
14. Addition of "daytime" flash-to-pass capability on vehicles equipped with optional Xenon HID headlamps (Y42 & Y43 Packages)
15. Reverse tilt-down sideview mirror feature/option added once again to vehicle personalization
16. 2010 CTS sales brochures:
> USA version (abridged) - http://www.keepandshare.com/doc/2856490/2010-cadillac-cts-brochure-usa-abridged-pdf-june-7-2011-11-20-am-184k?da=y
> Canada version - http://www.keepandshare.com/doc/2856489/2010-cadillac-cts-brochure-canada-pdf-june-7-2011-11-20-am-4-3-meg?da=y
2011 Cadillac CTS
2. New design front fender vents
3. Addition of (rpo UVC) rearview camera to Y40 Level One Luxury Package
4. Addition/availability of (rpo FE5) 19" All-Season Tire Package. Includes (PJ2) 19" x 8.5" polished wheels, (Q2B) P245/45R19 all-season blackwall tires and (KB7) steering wheel mounted Paddle Shift Controls
5. 'Cadillac' script added to trunk lid-mounted chrome accent piece
6. Seat belt latch plate pieces changed to much larger, heavier design (from Chevy/GMC Truck parts bin?)
7. Interior rear view mirror changed to smaller size design with fewer buttons; mirror incorporates small video screen for rearview camera view on Y40 Package-equipped cars (that are not equipped with optional (UAV) Nav/Infotainment System)
8. Heated steering wheel added to (PDW) Performance Luxury Package
9. 2011 CTS sales brochures:
> USA version - http://www.keepandshare.com/doc/2856492/2011-cadillac-cts-brochure-usa-pdf-june-7-2011-11-20-am-3-4-meg?da=y
> Canada version - http://www.keepandshare.com/doc/2856491/2011-cadillac-cts-brochure-canada-pdf-june-7-2011-11-20-am-4-0-meg?da=y
> CTS Sedan Select Specifications (USA) - http://www.keepandshare.com/doc/2856493/2011-cadillac-cts-sedan-select-specifications-usa-pdf-june-7-2011-11-20-am-1-1-meg?da=y
http://i248.photobucket.com/albums/gg195/RAB_2008/10CACT06595_Wallpaper_859.jpg
:spin:
Brutus
06-07-11, 07:57 AM
Nice work, thanks so much for the good post.
underpsi68
06-07-11, 08:49 AM
Thank you for the nice write up.
M.Dubb1969
06-07-11, 10:18 AM
RAB,
Wow, and thank you very much! Exactly what I was hoping for!
928S
06-07-11, 11:23 AM
:2thumbs: Great stuff, RAB. Thanks.
MODERATORS, for your consideration, please: RAB's post #6 above with ongoing updates should be a standalone sticky at the top of this forum's main page. It's the answer to many recurring questions, so let's preserve easy access for all to see.
JimmyH
06-07-11, 04:31 PM
I copied RAB's post to the faq and pinned it. You guys need to start populating that thread. Get some more info in it, and I will index it all in the first post.
somedaycts
06-07-11, 10:27 PM
Great post RAB, though I think it is important to comment on one thing that is asked frequently on this forum:
Bluetooth is not standard on all iterations until 2012 M.Y. Previous to 2012 M.Y. it was packaged with the Y44 seating package (leather seats with power passenger and driver memory). If the car does not have Y44, it does not have Bluetooth.
928S
06-08-11, 10:25 AM
also
Heated Washer Fluid System (RPO XA7) was deleted after September 2008; factory installed in CTS 2008MY 53,305 units, CTS 2009MY 18,517 units (source: GM/DOT/NHTSA recall document).
___________________________
I'll post these two items as an addendum to the FAQ thread, "CTS Model Year Feature Changes - Comprehensive List."
RAB
06-08-11, 11:53 AM
somedaycts, thanks. Apologies for the error re Bluetooth application/availability (i.e. on vehicles built for the US).
Your info is helpful in a couple of ways, as I've realized now that I left out Y44 Seating Package info entirely in my original listings in post #6 of this thread. Actually I gave zero thought to the Y44 Package because of where I live! Every 2008+ CTS (every iteration) built for Canada comes standard with the Y44 Seating Package (and therefore Bluetooth since late m-y 2008).
As info.. all 2008+ CTS's built for Canada also get the (ZAA) Compact Spare Tire as standard equipment, as opposed to it being an option in the US.
I'm unable at this point to edit my post #6 (more than 24 hours have passed), therefore will provide info here about Y44:
Y44 (m-y '08) - Seating Package - Includes leather seating surfaces, 8-way power passenger seat, 2-way power driver and front passenger lumbar control, Memory Package, heated front seats, and heated washer fluid system. [Info taken from '08 CTS sales brochure/USA]
Y44 (m-y's '09 & '10) - Seating Package - Includes leather seating surfaces, 8-way power passenger seat, 2-way power driver and front passenger lumbar control, Memory Package, heated front seats, Universal Home Remote, and (UPF) Bluetooth phone [Info from GM online order guide]
Y44 (m-y '11) - Seating Package - Includes leather seating surfaces, 8-way power passenger seat, 2-way power driver and front passenger lumbar control, Memory Package, heated front seats, Universal Home Remote, (AP9) trunk convenience net, (BNK) Underhood Appearance Package and (UPF) Bluetooth for phone [Info from GM online order guide]
M.Dubb1969
06-08-11, 12:16 PM
RAB,
Concerning the Reverse/Tilt-Down passenger and driver side mirrors on the 2009 m-y. My CTS is a 2009 m-y built in Aug 2008. It has this feature and it is able to be turned on/off in the DIC custom settings. Maybe this was deleted later in the m-y builds?
RAB
06-08-11, 12:28 PM
also
928S - thanks. Great job digging up that info. :thumbsup:
Hadn't realized that early m-y 2009 CTS's (18,517 of them!) were factory-equipped with the Heated Washer Fluid System.
Thanks as well for recommending to moderators that my post #6 be copied to the FAQ thread, "CTS Model Year Feature Changes - Comprehensive List". I wish the copied post could be left 'open' for further editing by me. If that was the case I could make continuing changes and corrections as necessary.
Moderators / JimmyH - can you change the settings for my post in the FAQ thread to permanently allow editing?
RAB
06-08-11, 02:28 PM
RAB,
M.Dubb1969, thanks. Regarding the "Park Tilt Mirror" feature... my 2009 m-y CTS was built in late May 2009 (some 9 months after your '09 CTS was built) and there's no option on my vehicle in DIC Vehicle Customization to turn the feature on/off. The feature was evidently removed at some point during 2009 m-y production. Who knows?.. perhaps it was mistakenly left out later in 2009 m-y production at a time when a revision was made to DIC vehicle customization software. A short time after it was removed (on mid or late m-y '09's) the feature mysteriously returned when they began building the 2010 m-y CTS, in July 2009. I wish Cadillac would make up its mind about this! :bonkers:
It's interesting to note that Park Tilt Mirrors are not even mentioned in the 2009 CTS owner's manual (or the 2010 & 2011 owner manuals). The feature is however mentioned/explained in the 2008 owner's manual, as well as, I've just noticed, in the "2009 Cadillac CTS Customer Convenience/Personalization Guide", on page 11. Here's a link to the 2009 guide for anyone interested in downloading it: http://www.keepandshare.com/doc/2252733/2009-cadillac-cts-customer-convenience-personalization-guide-pdf-september-20-2010-8-36-am?da=y
I had the Park Tilt Mirror feature in my 2008 CTS4, however ended up turning it off after a few weeks of using it. I found that my preferred (memory set) position of the mirrors would always "drift" after a number of park (reverse) operations. I was forever correcting the position of my mirrors!
These days, if/when I need to see the curb during a parking manoeuvre, I'll just tilt the mirror down 'manually' using the mirror controls and then bring it back to its original position (if I choose to stay in the car) using memory recall. Otherwise.. an exit/auto-lock/re-entry sequence will do the memory recall for me.
M.Dubb1969
06-08-11, 03:31 PM
RAB,
Cadillac does seem to change their mind a lot. Just to clarify, when you say that the park/tilt feature is removed in vehicle personalization, do you mean that there is no park/tilt feature at all, or do you mean that it is there, but the owner just can't turn it on or off? Thanks for the link to the Customer Convenience/Personalization Guide. My used car did not come with any manuals at all. But, the curious thing is that I did download a 2009 CTS Owners Manual from somewhere online the day I bought the car. That downloaded copy does mention the park/tilt mirrors in section 2-54.
Thankfully, I have not had the mirror drift problem when using the feature. So far I'm really loving the car. I have a few issues that I want the dealer to take care of (I'm still under warranty), but I think it's a great car. I took a big leap of faith after driving Hondas for the last 15 years!
RAB
06-08-11, 04:24 PM
M.Dubb1969, I meant there is no park/tilt feature at all on my '09 CTS - it is not there, not listed in vehicle personlization.
I just found the brief reference to Park Tilt Mirrors in the '09 CTS owner's manual, page 2-54. [Good find! I hadn't looked there earlier today.. I was looking (only) through the DIC Vehicle Customization pages, for any ref to setting up Park Tilt Mirrors]. The wording on page 2-54 is interesting, in that it mentions, "If the vehicle has this feature....".
In the '08 CTS owner's manual, detail about turning the Park Tilt Mirror feature On or Off (and which mirrors - Passenger and/or Driver mirror) is provided in the DIC Vehicle Customization section. This same information (contained within the DIC info section of the '08 manual) is completely absent in the '09 and subsequent m-y owner's manuals.
Glad to hear you're really loving your '09 CTS! :thumbsup: I hope you continue to enjoy it.
After driving a fully-optioned 304HP 2008+ CTS for almost 4 years now, I must say I am still very partial to the car. There's really no other sport sedan I'd want to purchase at the moment.. certainly nothing in the same price range. My wife and I are looking to get a luxury crossover vehicle within the next 6-12 months, so there could be a 308HP LFX-equipped 2012 SRX Premium sometime in our future. Maybe. ;) It will be hard to give up my CTS.
Stoneybroke
06-10-11, 12:38 AM
Rab: I'm starting to think that we should never say never with the CTS. I have 2010 wagon, early build in May of 2009. The car has (CE1) rainsense wipers, (CE4) headlight washers, (G80) Positraction rear axle with FE2 in AWD, and (J55) Hvy duty brakes. All of the above comes from the build sheet. Go figure!
RAB
06-10-11, 08:58 AM
Stoneybrook, go figure is right! Your early build 2010 CTS Sportwagon was built at the exact same time (May of '09) as my 2009 CTS Sedan. Although your Sportwagon is labeled a 2010 m-y vehicle, it has the content of a 2009 m-y car!
All info/details provided in my post #6 pertain specifically to the CTS "Sedan". I stayed away from including detail on the other eventual CTS bodystyles for a few reasons: too big a task.. too big a post (I think it was already overly long & complicated).. and frankly my unfamiliarity with the finer points of standard content info and option/package detail of the CTS Sportwagon and CTS Coupe.
C "T" ess
06-11-11, 01:01 PM
My 2010 feb 2010 build date does not have the outside review mirror tilt option.
MotownPimp
06-11-11, 03:13 PM
I know it is only June but between his work here and the 5.1 surround sound post, anyone else think we ought to declare RAB the winner of the prestigious ( :hmm: ) "Member of the Year" of the year award?
:highfive: :2thumbs: :cheers: :cheer:
Nice work, RAB.
RAB
06-12-11, 01:12 PM
Thank you for your comments Motown! :thumbsup: You're too kind.
Member of the Year??!! :histeric: That's funny!
Hmm... shouldn't the winner of that be treated to a few free beverages along with some personalized dances at Chez Paris? :tits: I'd definitely be up for that one! (Motown - have you ever been north to Canada? We have some nice bars up here. ;) )
:cheers:
MotownPimp
06-12-11, 02:11 PM
Growing up in Detroit, I've been in Canada several times. Most extensive was a trip from Windsor to Sudbury and then over to upper Michigan on a BSA Lightning in 1967. :cycle:
Evidence:
76458
More important my girl of 36 years was born in Windsor. Her ancestry includes Noel Fortier who sailed to Quebec from Normandy, France with his family in 1643.
Y'all grow 'em pretty north of the border. Evidence:
76457 :excited:
:beer:
RAB
06-13-11, 03:10 PM
Motown, great stuff! You're a lucky man. :highfive:
Yes indeed.. we do grow 'em pretty north of the border.
36 years?! Very impressive. Was her reward (you know.. for putting up with you all that time) the 2011 CTS Coupe?!! :histeric:
You can tell us all now.. is the Coupe your car.. or is it really HER car? :D
:canuck: :beer:
MotownPimp
06-13-11, 07:04 PM
Naw; she does not like all the shifting with the stick...though she actually runs through the gears cleaner than I do. She is a speed freak though, though. Did not realize it until a few rides in the Z where I would get up to 130 or so. (Under very safe conditions).
Among her other rewards is a Lexus RX350 which she loves: sits up high, feels safe, & runs smoooooth. Here is shot of her with it the day it arrived on flat bed.
76485
76486
One of our favorite fun activities is long drives with some of the 4000 songs I've accumulated. I like to say "I got my girl, my car, and my tunes; life is good". :D
MotownPimp
06-13-11, 07:17 PM
Apologies to the OP for "stealing" the thread. It drives me a little when others do it to my posts.
76487
Promise not to make a habit of it.
:sadeyes: :sorry:
sterling
10-04-11, 03:52 PM
So, if a 2008 CTS has the 18" wheels, then it definitely has either the Y42 or Y43 performance packages, right? If anyone can let me know it would really help!! Thanks
RAB
10-04-11, 05:34 PM
sterling, that's correct. If a 2008 CTS has factory 18" wheels installed then it can be assumed the car is equipped with either the Y42 (FE2) package or the Y43 (FE3) package. To be sure however about what the car has or doesn't have (equipment & package-wise), the vehicle's rpo sticker should be reviewed. The sticker is located on the underside of the spare tire compartment cover.
Although the same basic wheel design, the 18" wheel on an '08/'09 CTS was available in a painted finish (rpo P75 wheels) or a high-polished finish (rpo P63 wheels). Y42/FE2 came standard with painted-finish 18" wheels, with the high-polished finish 18" wheels available at extra cost. Y43/FE3 came standard with the high-polished finish 18" wheels.
sterling
10-04-11, 07:13 PM
Awesome! Thanks for the great answer. Haha hopefully I'll be posting in the forum soon, I had a cts of the previous generation until recently. The looks of the light platinum CTS with off white interior leather is stunning..must..have it!
FrankRizzo
10-05-11, 10:11 PM
The light platinum interior is beautiful but difficult to keep clean, at least in my experience. Almost any contact with the door panels or other hard plastics seems to mark them up, and they aren't easy to clean - had to use a magic eraser. The dye from jeans transfers to the seat and is also tough to clean. Also, the rubber seals around the door openings are a light color as well and become yellowish over time, not to mention show dirt very well. Just an FYI.
greyghost04
10-06-11, 09:55 AM
BTW, if you have an older CTS that still has the wiper water heater you can turn it back on by just reinstalling the fuse. I don't think they actually took them out. They worked just fine. The problem was a little old lady that stuck the button 'On' and caused a little smoke. That's what caused the recall. Mine worked just fine in the winter.
928S
10-06-11, 11:35 AM
GM recall requires dealer removal and disposal of heater module and fuse. So 2008-09 CTS Heated Windshield Washer System is intact only if 1.) recall was not performed on the vehicle, or 2.) aftermarket AlphaTherm replacement unit and fuse were installed after the recall was performed.
Although risk of fire was minimal (~0.0056% of installed units), recall documents (http://nhthqnwws111.odi.nhtsa.dot.gov/acms/documentList.do?docId=10V240&docType=RCL&fromPublic=true) reveal "four fires are believed to have occurred due to the failure of the [heater module] solder cup. Three of these occurred while the vehicles were unattended." And, reportedly, at least one of those fires damaged or destroyed the vehicle owner’s attached garage and residence.
My OEM unit worked just fine, too. Now the AlphaTherm replacement is even better. Great for summer bugs or winter frost.
JimmyH
10-06-11, 01:05 PM
I suspect that is why black interiors are so popular these days.
