View Full Version : engine stutter on 1994 fwb
newside
05-30-11, 01:13 AM
hi all, i'm having an intermittent engine stutter on my 94 fwb. it usually starts around 45 and up, and on hills. when i accelerate from cruising it will stutter. what i have done to the vehicle is, change the tranny fluid and filter, change the fuel filter, replaced the intake gasket, replace air filter and engine oil. i checked the engine at night for arching around the plug wires. i was thinking about the torue converter lock-up as a possiblity. any impute would be appreachiated. thanks
sven914
05-30-11, 02:31 AM
Try replacing the plugs and wires.
Stingroo
05-30-11, 10:11 AM
Check your EGR valve.
jayoldschool
05-30-11, 10:52 AM
Replace coil wire only, first. Inspect, clean, lube connections for the coil/ICM.
newside
05-30-11, 11:21 AM
ok, thanks guys. i'll try these suggestions. i just got the carburator done on my 79 deville. it's one thing after another. lol, thanks again
HUF
05-30-11, 11:29 PM
ok, thanks guys. i'll try these suggestions. i just got the carburator done on my 79 deville. it's one thing after another. lol, thanks againKeep us updated. I have had exactly the same issue for two years. Still looking for possible cause...
Wheelman322
05-31-11, 10:15 AM
Possibly a bad Optispark...I know the LT1 engine was known for that.
HUF
05-31-11, 02:01 PM
I have checked the coil wire on my 95 LT1 and it was super clean. The resistance was 2.5 kOhm, which is normal for a 12" plug wire. The ICM area was superclean as well. Probably the wire is not MY problem. Will keep investigating.
turbojimmy
05-31-11, 04:06 PM
Can you power through it? For example, will it stop "stuttering" when you give it more gas? If so, it's probably the TCC solenoid.
If it's not missing/stuttering under any other circumstances, it's probably the solenoid not holding and thus allowing the converter to lock/unlock rapidly until the PCM calls for a TCC unlock.
newside
06-02-11, 11:52 PM
turbojimmy, i can power through the stutter. i checked the wires and they have been replaced, the icm is clean, no corrostion. i think it is the tcc solenoid as the car runs excellent throughout it's operating ranges.
HUF
06-03-11, 06:01 PM
Do not jump to conclusion yet... Have you ever checked your exhaust manifold bolts and studs? If you have not done it , the chances are you will find some of them loose, missing or snapped/sheared off... A very common problem of all LT1 engines. I have recently tightened only two bolts on the driver side because I saw small exhaust leak - bubbles coming from the edge of the gasket when some water was sprayed over it. That leak is gone and believe it or not he throttle response is better now. I cannot say for sire that my stutter is history, but it has not occurred today under conditions it usually would do. Check the bolts. Replace them with grade 8 flange hex bolts black finish. You need 3/8"-16 x 1.000" and 3/8"-16 x 1.500" bolts. See if it helps.
newside
07-14-11, 06:28 PM
ok guys, been awhile since i've got back to this problem. i replaced the tcc lockout solinoid with no luck. i tightened the exaust manifold bolts with no results so now i'm going after the plugs and wires
thefleetwoodguy
07-14-11, 07:43 PM
wires
drmenard
07-14-11, 08:14 PM
If it's not the wires its the cap and rotor... But more than likley it will take plugs, wires ,cap and rotor...
HUF
07-14-11, 09:57 PM
I believe it is in human nature... starting with the most difficult part! lol
newside
07-14-11, 10:04 PM
thanks guys, i checked the ground at the coil, icm all ok. the wires were replaced by someone but, they could have been the cheaper ones and are breaking down. i will replace them. does the water pump have to come off to replace the cap and rotor?
outsider
07-15-11, 08:30 AM
yes, the water pump does have to come off :(
newside
07-16-11, 10:04 AM
ok guys i found the cause of the stutter, as i replaced the wires i new they were to new to be the problem, but when i removed the last plug on the drivers side i had to heat it out, it was froze good. when i did get it out it was covered in a thick white build up. that's the one that was nagging me. i'm not sure how it got that way but it runs great
jayoldschool
07-16-11, 04:41 PM
Can we see a picture of the plug, please? Use the "macro" setting on your camera.
newside
07-16-11, 10:18 PM
sorry jayoldschool, i don't have a camera, i have to borrow one. the build up could be anti freeze. i'm going to keep an eye on that cylinder. i did replace the intake gaskets a short time ago and i hope the head gasket isn't seeping abit
