View Full Version : List of V2 TSB's & Safety Bulletins?
js615
05-27-11, 11:53 AM
Love the forums for just this sort of thing - when I traded up to the V2 from my V1, I spent a few hours searching the forum and ended up with a nice list of things to have my dealer check out and repair (still scratching my head over the wheel click issue - so bizarre really). Anyhow, it saved me time and headaches down the road - thanks to all who share their good info and insight here; it's not all just about mods...
That said - why not have a sticky thread listing known TSBs, SB's, or other known issues?
serturbo
05-27-11, 12:24 PM
If you research it, post it and keep it up to date, I'm sure the mods will sticky it.
js615
05-27-11, 02:32 PM
OK then - here's whatI've compiled thus far - I'm sure there are more I'm missing...please add to the list.
J.
Cadillac CTS-V TSB’s
Models: 2009
NHTSA Number: 10037356
Service Bulletin Number: PIC-5136D
Date of Bulletin: Nov 01, 2010
Component: Wheels
Summary:
Models: 2009, 2010
NHTSA Number: 10037307
Service Bulletin Number: SB-10-07-29-002
Component: Power Train
Summary: GM: there may be an intermittent hard to shift into gear.
Models: 2010
NHTSA Number: 10033364
Service Bulletin Number: PIE-0047
Date of Bulletin: Oct 01, 2010
Component: Fuel System, Other
Summary: General motors: engineering information-chemical damage on inner surfaces of fuel tank. Some customers may comment on poor performance, decreased acceleration and/or an inoperative fuel gauge.
Models: 2010
NHTSA Number: 10036026
Service Bulletin Number: PI-0242
Component: Latches/locks/linkages
Summary: Cadillac: interior door latch release switch inoperative. Front door can only be opened using the inside manual release handle. CTS and CTS-V coupe
Models: 2009, 2010
NHTSA Number: 10037184
Service Bulletin Number: 05-09-40-002E
Component: Seat Belts
Summary: GM: service bulletin explaining when the safety belts are supposed to lock.
Models: 2010
NHTSA Number: 10036344
Service Bulletin Number: PIP-4819
Date of Bulletin: Aug 01, 2010
Component: Engine And Engine Cooling
Summary: Cadillac/Chevrolet/GMC: ses light due to p0300-p0308 and engine misfires; inspect plug wire. This may be the result of a loose spark plug wire of the cylinder with current and/or history misfires
Models: 2009
NHTSA Number: 10035924
Service Bulletin Number: SB-10-08-42-001A
Component: Headlights:High/Low Beam Dimmer Switch
Summary: Buick/Cadillac/Chevrolet/GMC/Pontiac/Saturn: low beam headlamp bulb diagnosis/replacement (inspect bulb and connector). Does not apply to vehicles equipped with high intensity discharge (hid) lamps. Do not replace the entire headlamp assembly.
Models: 2009
NHTSA Number: 10034408
Service Bulletin Number: PI-0082
Date of Bulletin: Apr 01, 2010
Component: Exterior Lighting
Summary: Cadillac: center high mounted stop lamp (chmsl) housing cracked, leds inoperative, contact with rear compartment lid, paint damage. Revised chmsl has been released for service. It features additional clearance to the rear compartment lid.
Models: 2009
NHTSA Number: 10032325
Service Bulletin Number: SB-09104
Date of Bulletin: Jan 01, 2010
Component: Structure
Summary: Cadillac service campaign: see document search button for owner letter. Front door latch freezing. Water enters the latch housing and freezes. May not be able to open the front doors using the outside door handle, or the door may not latch.
Models: 2009
Models: 2009
NHTSA Number: 10032894
Service Bulletin Number: PIC-5175
Date of Bulletin: Jun 01, 2009
Summary: Cadillac: some customers may comment on a afl lamps need service message displayed on the dic. The adaptive feature of the headlamp is inoperative. Engineering is attempting to determine the root cause of the afl headlamp system not operate.
Models: 2009
NHTSA Number: 10030790
Service Bulletin Number: PIC-5083
Date of Bulletin: Feb 01, 2009
Summary: Cadillac: front doors may not open or close during cold weather. One or both front doors may not open using the outside release handle in subfreezing temperatures. The door can always be opened using the inside release handle.
Models: 2009
Cadillac CTS-V Recalls
Models: 2009, 2010
Campaign Number: 10V414000
Manufacturer: General Motors Corp.
Report Date: Sep 13, 2010
Vehicles Affected: 20224
Component: Equipment
Summary: GM is recalling certain model year 2009-2010 Cadillac CTS AWD and CTS-V vehicles for failing to comply with the requirements of federal motor vehicle safety standard no. 208, "occupant crash protection."
Consequence: In the event of a crash, the front passenger may be at an increased risk of leg injury.
Remedy: Dealers will replace the glove compartment assembly and, in some vehicles modify the instrument panel structure. This service will be performed free of charge. The safety recall began on October 20, 2010. Owners may contact Cadillac at 1-866-982-2339.
baabootoo
05-28-11, 12:27 AM
"ALLDATAdiy.com" lists them, but w/o the details. You have to pay to get them.
EricVonHa
05-28-11, 12:48 AM
Whatever you do don't let the dealer do the glovebox modification. If you saw the photos of what is required of them you will run. It requires manual use of a saw, block of wood and a fair amount of cutting.
dqw1
05-28-11, 09:49 AM
I had the glovebox recall done and I seen no issues with the work performed.
