: Squeeky pop up display...
shchow
05-25-11, 01:55 PM
Noticed that since the temperature has gotten warmer, my pop up display squeaks when going up.
Kind of embarassing, especially if there is a guest in the car.
Anybody have a good solution?
Domsz06
05-25-11, 02:16 PM
white lith grease?
hulksdaddy
05-25-11, 04:39 PM
I'm not in front of mine, but I assume we can't get to the inner workings, correct? Is the squeak mechanical, or a plastic creak? If the latter, maybe some protectant around the dash are where it rises from. Should help lube that area(if that's what it is)
Caddy Wagon
05-25-11, 07:31 PM
I'd be headed to the dealer for a warranty repair.
tedcmiller
05-25-11, 08:48 PM
My CTS-V is a 2009 and I have never had the problem you describe at any temperature.
vseries
05-26-11, 12:33 AM
mine did this last summer, I am waiting for the weather to get warmer to check it this year. If it does I will be fixing it myself, I can do without all the additional scratches someone else would cause.
neverl8
05-26-11, 01:10 AM
Mine just started this also. No dealer for me until it fails. They will jack it up worse!
Busabob
05-26-11, 09:20 AM
Mine does it too, when it's hot (direct sunlight on dash)
BLitzkrieg
05-26-11, 10:01 AM
Ditto!
RapidRob
05-26-11, 10:45 PM
Ditto - just for the record.
Rob
shchow
05-29-11, 10:16 AM
So I guess I'm not the only one.
I figure it's the housing that's rubbing and not any internal gearing component.
I agree with what others have said about the dealer, don't want them scratching things up.
Will try topical silicone/lubricant and see if that takes care of it...
PhxTriode
05-29-11, 08:36 PM
Dealer fixed mine with some lubricant. Only happened when it was warm out.
sotxmike
05-29-11, 10:24 PM
Mine does it also. I solved it by turning the stereo up. That solved the wheel clicking too.
