: Help-91 cadi 700r4 in a 85 coupe????????
85 FLEETWOOD COUPE
05-24-11, 06:04 PM
Hello cadillac guys i got a question i need to know, i got a 1985 cadillac fleetwood brougham coupe that i had removed the old 4.1 and tranny to replace it with a carbed chevy 305 and 700r4 tranny that came out of a 1991 cadillac fleetwood brogham, do i need a lock up kit for the 700r4 or i should be good with out it?? Some say i dont need it and others say i need a lock up kit,any help please guys im doing this swap real soon but need to know this to do it
sven914
05-24-11, 06:26 PM
If you are talking about the Lockup Torque Converter Clutch, then you don't need one. The TCC only makes the car (slightly) more fuel efficient by eliminating slip in the driveline. For this reason it also helps the transmission to stay cool; the slippage generates heat. But the TCC usually isn't applied for very long at a time and most of the cooling is done by the transmission cooler. So having one would only increase your economy by about 1-2 MPG.
85 FLEETWOOD COUPE
05-24-11, 06:53 PM
Ok cool thanks, so no need for a lock up kit, a oil cooler for the tranny maybe?
cadillac kevin
05-24-11, 06:57 PM
unless you live in the mountains or plan on taking long trips through the mountains hauling alot of weight (either on car or towing a trailer) an external trans cooler isnt needed. if you just plan on driving the car around town and on the occasional road trip it'll work fine without one.
85 FLEETWOOD COUPE
05-24-11, 07:00 PM
Wow thanks alot kevin this really helps alote!!!! Alot of people was telling me if you dont use 1 it will burn up the tranny quicker,thanks again
85 FLEETWOOD COUPE
05-25-11, 02:20 PM
JUST TO BE SURE,DO ANY 1 GOT INPUT ON THIS OR AGREE WITH sven914 OR STEVE?
sven914
05-25-11, 02:56 PM
I agree with myself...
Go to a small, family owned transmission shop, and ask them. Make it clear that you will be installing the kit yourself so they won't be biased on trying to sell you a TCC, and they will probably give you an honest opinion.
85 FLEETWOOD COUPE
05-25-11, 04:07 PM
There is no honest tranny shop around here that i trust lol
csbuckn
05-25-11, 09:08 PM
I agree also, just pop it in. That stuff isn't really needed, just nice to have.
85 FLEETWOOD COUPE
05-25-11, 10:46 PM
alrighty cool, so just change the oil filter and oil while its out right
csbuckn
05-25-11, 10:55 PM
Yep, and the front and rear seals.
85 FLEETWOOD COUPE
05-26-11, 01:50 AM
you mean the 1 peice main seal? whats the rear seal called? where it goes?
85 FLEETWOOD COUPE
05-28-11, 08:07 AM
to th top
csbuckn
05-28-11, 09:16 AM
The front seal goes in the front of the tranny after you take the converter off, it is a one piece seal and might be called the front pump seal. The rear seal(not sure the official name) goes in the back around the hole that the driveshaft goes in.
85 FLEETWOOD COUPE
05-28-11, 07:49 PM
I got a rear main seal 1 peace, is this what goes inbetween the motor and tranny??
jayoldschool
05-28-11, 08:05 PM
No, the rear main seal goes on the end of the crank in the engine block.
85 FLEETWOOD COUPE
05-29-11, 08:35 PM
o ok cool thanks hope to get going soon, been real sick lately but will keep you guys updated thanks again
