View Full Version : 2000 Deville Speakers
386 DeVille
05-24-11, 11:22 AM
So, I just bought a 2000 Deville which has the UX8 RPO. To my understanding, this is supposed to be an 8-speaker system. But, I only count 7. Correct me if I'm wrong, but I count 2 a-pillar tweeters, 2 front-door speakers, 2 rear-door speakers and a rear-deck subwoofer.
Also, what size are each of these so that I may replace them. I'd also like to install my two Kenwood 12's, which pretty much requires an aftermarket HU. Any obstacles I should know about here?
386 DeVille
05-24-11, 02:33 PM
OK, so it appears the eighth speaker may be in the center of the dash. Even still, I need to know the sizes of all speakers, please. Plus the other stuff I asked.
baller95
05-24-11, 10:33 PM
Center Channel 3.5
A Pillars 2 inch
Front Doors 6.5
Rear Doors 6.5
Sub 10
Make sure u get a good harness, i think its a GMOS-06 ?
386 DeVille
05-24-11, 10:42 PM
Would I sacrifice a lot of bass if I just used a LOC from the factory sub wires to my external amp for my 12's?
baller95
05-25-11, 04:42 PM
Not too much of a difference but you're probably better off doing it like that too. The factory radio is controlling lots of things which is why you don't wanna mess with it too much.
386 DeVille
05-30-11, 09:52 AM
So, I plan on getting a set of components for the front. I intend to use the factory mountings for both the woofers (doors) and tweeters (a-pillars). My question is, if I will be utilizing the factory amp, can I just use the factory wiring for both and not worry about the provided crossover? I'm assuming here that the factory amp has a built-in crossover for the tweeters. If this is not ideal, how should I do it?
Also, my car's speakers are as follows:
Center Channel 3.5
A Pillars 2 inch
Front Doors 5.25
Rear Doors 5.25
Sub 10
baller95
05-30-11, 03:23 PM
That I'm not sure about ^ but there should be others who can help
misslacey
09-11-14, 02:41 AM
can anyone tell me why everyone keeps saying not to mess with my stock radio in my 2000 Sedan Deville??
Submariner409
09-11-14, 09:06 PM
The sound system head unit (the radio) is part of the car's serial data bus, TheftLock system, content theft system - and is programmed with the car's VIN (Vehicle Identification Number). There are specific workarounds and hardware procedures needed to modify the system. Do it incorrectly and you lose some warning chimes, security functions, and in some cases the car refuses to even start.
Avaya
09-15-14, 12:35 PM
I can't tell if you have the Delco or Bose system. If you are going to replace the door speakers, make sure you have the ohm right. The factory amp is not made for 4 ohm.
I've got the Bose system and am not going to touch anything other than replace the stock 10" with my good quality 10"s and amp. Going to use a LOC from the stock sub to my amp. Have all the parts, just haven't done it yet.
