: 92 Brougham with brake fluid leak.
05-24-11, 04:41 AM
I have a 1992 Brougham with no front brakes. I pulled the right front (passenger) tire off and I found it leaking from the conNection where the galvanized line meets the rubber line. What would be the best way to repair the leak? Keep in mind that this car sat for 6 years prior to my purchase and the galvanized lines look like carp. Probably still the stock lines.
Further more, where would be the best place to purcahes the brake lines and that box that the left and right brake lines split from (what is that name of that box)?
05-24-11, 07:15 PM
It's either the hose or the metal line itself. The only way to fix it is to replace the part that's leaking. You might aswell replace the hose either way while it's apart because it will need it eventually.
