View Full Version : Service Stabilitrak TSB #06-02-35-002B
jellyhead
05-22-11, 12:35 AM
I have been having an issue with the Service Stabilitrak message being displayed on the DIC. I found this TSB
2004 - 2008: Service Bulletin: Stabilitrak/Active Handling Light On,
Service Stabilitrak/Active Handling Message on DIC
Subject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710
Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007)
Models:
2004-2008 Cadillac XLR
2005-2008 Chevrolet Corvette
with Steering Wheel - Tilt, Telescoping (RPO N37 or N38)
Condition
Some customers may comment on a Stabilitrak® or Active Handling System light being illuminated. Also, this warning light
will be accompanied by a SERVICE STABILITRAK or SERVICE ACTIVE HNDLG message on the DIC.
Diagnosis with a scan tool may reveal a DTC C0710.
Cause
The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS
connector C202. Fretting terminal corrosion may be present in the SWPS connector due to the telescoping motion of the
steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may
move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in
the SWPS connector.
Correction
Remove the driver's side closeout (insulator) panel.
Locate the SWPS connector that connects to the steering angle sensor, located on the lower center of the steering column.
Install the clip (1), P/N 19179794, into the connector. This clip will act as a terminal positive assurance (TPA) and prevent
any movement of the terminals.
I checked for the DTC and there was nothing but with the car running I ran the steering column in and out a few times and noticed the message changed from Service Stabilitrak to Traction Control SYS Off.
Has anyone performed this fix and is there a step by step guide?
alarmu12
06-08-11, 10:30 PM
I am having the same problem with my 07 XLR. It has been to the dealer 4 times and a few days later the traction control and the stabilitrack lights are back on again. When I restart the car it sometimes goes away and sometimes it does not go away. Sometimes the message goes away, but the car with the lock light stays lighted. Any help would be appreciated.
alarmu12
06-10-11, 05:09 PM
Yesterday I drove the XLR and while I was driving it I put the steering wheel in and out and sure enough several dash lights came on and the trans locked in the 3rd gear emergency mode. Thanks for the advise that the dealer did not know about after 4 trips to it.
alarmu12
06-15-11, 11:04 PM
I went in and had the above service done and I am still having problems. They are searching now with 3 more days in the shop and still counting.
alarmu12
06-18-11, 05:50 PM
Got it back with the pcm replaced and reprogrammed. The lights are out for now.
ccclarke
06-19-11, 09:15 AM
Which module was replaced to restore StabiliTrac? (No PCM on the XLR.) Was it the EBCM (Electronic Brake Control Module?)
CC
alarmu12
06-19-11, 03:59 PM
It says PCM shorted J6360 replaced and programmed PCM. Set electrical 423 WC4 , 1 19210736 ECM Cal state 874299.
46653 shorted PCM. J6360 1.60 follow the diagnosis test and replace PCM, reprogram PCM, ck PCM connectors, perform crank position relearn, set electrical.
Crestview Cadillac in West Covina, Calif. Has a good man Gordon Armstrong, who will not give up, no matter how long it takes to solve a problem. His knowledge is really deep on the Tach II.
