View Full Version : I really need help OBD TROUBLE CODES 96 STS
conflicting
05-16-11, 09:15 PM
I love this car, but it has some problems. I would love to start working on it but I cannot figure out how to define the obd codes. I have searched in google and this forum but the codes just do not match up? a link would be wonderful. even better if somebody has the time to tell me how to fix and what the codes actually mean!
pc0131
pc0151
pc0171
pc0174
pc0603
pc1571
pc1602
pc1644
rz1558 history
rz2042 current
the car has 160k. the abs light, traction control light is on. car doesnt seem to want to go when you step on it, my eldorado was way faster. brakes are squeaking ( is that why the abs light is on?). car shifts fine w/ normal driving but when you floor it it doesnt downshift like its supposed to. after car starts it says check emmissions system.:bouncy:
89falcon
05-16-11, 11:10 PM
pc0131
pc0151
pc0171
pc0174
pc0603
pc1571
pc1602
pc1644
rz1558 history
rz2042 current
pc0131: HO2S Circuit Low Voltage Bank 1 Sensor 1
pc0151: HO2S Circuit Low Voltage Bank 2 Sensor 1
pc0171: Fuel Trim System Lean Bank 1
pc0174: Fuel Trim System Lean Bank 2
pc0603: PCM Memory Reset
pc1571: Traction Control PWM Ckt No Frequency
pc1602: Loss of EBTCM Serial Data
pc1644: Delivered Torque Output Circuit (EBTCM related....)
rz1558 history
rz2042 current
Check your connections......
You don't have power because you're running very lean.....and it doesn't look like you EBTCM is talking to the PCM
00 Deville
05-16-11, 11:17 PM
falcon was kind enough to define you codes for you... in the future the list can be found here.
http://myweb.accessus.net/~090/dtcobd2.html (http://myweb.accessus.net/%7E090/dtcobd2.html)
Submariner409
05-17-11, 09:10 AM
Yep, that link is in the sticky post ^^^ "How to pull codes" at the top of this forum's page of threads- as well as the link to OBD1 codes.........
P0171 and P0174 usually point to vacuum leaks. That will also set the lean codes.
conflicting
05-18-11, 10:40 PM
89 falcon... thank you so much for the list! now I have somewhere to start, just learned what and where the ebtcm is "__ ___ traction control mudule" .. what does the e and b stand for?
00deville... i ran acrossed that link multiple times searching for my answers and it did not have a list, nor did it seem like it was the right link, thats why I asked..
submariner, i will check for vacum lines thank you!
shoot me your paypal addresses, I will hook u up with a little something something :)
Ranger
05-18-11, 10:48 PM
EBTCM = Electronic Brake and Traction Control Module. It controls the ABS as well as the TC. Follow the brake lines from the master cylinder to it.
Look again. Up at the top under MASTER INDEX, you have to click on what code list you want. Manufacture Codes (xxx), Body Codes (Bxxxx), Chassis Codes (Cxxxx), Powertrain Codes (Pxxxx) or Network Codes (Uxxxx)
conflicting
05-19-11, 07:47 PM
ok ok, my codes have two letters pcxxxx ? i guess that doesnt matter? if it doesn't matter then how is one supposed to know that they are looking at the correct codes? pxxxx is not the same as pcxxxx i think that something should be noted about that? or maybe the codes should say pc? i dont know,,, this is just my ignorant opinion . maybe I am missing something?
conflicting
05-19-11, 07:49 PM
thank you thank you!!!! everyone!!! I know these questions are probably asked way to many times... but that is what a forum is about is gathering and discussing info.. I really apreciate it!
Ranger
05-19-11, 09:01 PM
Consider a PC code a P code.
Ranger
05-19-11, 09:04 PM
Oh yeah, I forgot to mention that '96 was the transition year from OBDI to OBDII so you may have some of each. Any codes you can't find in OBDII http://myweb.accessus.net/~090/dtcobd2.html will be found in OBDI http://myweb.accessus.net/~090/dtcobd1.html
conflicting
07-01-11, 11:17 PM
ok thank you... that clears it ALL up for me! I read that it was a transition year, but did not read anything that there might be a mixture of codes. so weird. I would expect cadillac to be more organized with something like obd codes. I think highly of cadillac and maybe I just have high expectations. thank you again
