: License Plate Holder / Tow Hook Kit
Dr. Design
05-12-11, 02:44 PM
2009-2011 Cadillac CTS-V Coupe / Sedan / Wagon
In many states you are required to have an unsightly front license plate. This typically requires you to have holes drilled into your pristine front fascia and mount a big bulky plate mount in the center of the vehicle. Unfortunately this does two things; reduces airflow into the vehicles cooling system & takes away from the look of the vehicle.
To prevent this D3 is proud to announce the release of our License Plate Mount Kit. This kit utilizes the OEM Tow Hook mount and does not require any permanent modifications to the vehicle for use. The kit offers multiple plate height settings and comes with everything you will need for installation. We even have optional finish plate mounting hardware. In typical D3 fashion the fit and finish is what you come to expect. MIL spec powder coat ensure corrosion resistance with hardware to match.
There is more to this then just a plate mount however. We also offer an optional tow hook mount that will also attach to the plate mount once the plate is removed. If you track your car or if you need a tow, just detach the plate and screw on the hook and you are ready to go.
Kit Includes:
* Offset License Plate holder
* Tow Hook Attachment
$129.95 | USD
Thank you,
Dr. Design
D3 Cadillac
05-12-11, 05:43 PM
Cool, but $130?!?!:alchi:
05-12-11, 06:25 PM
The tow hook is a nice touch. I wish I'd waited a week before going with the other option. $130 may seem a lot, but if you buy the other tow hook mounted plate AND a tow hook, the price is around the same or a little less.
05-12-11, 08:56 PM
I was gonna say...
05-13-11, 10:24 AM
Does it come with the tow hook? It says optional.
Dr. Design
05-13-11, 11:47 AM
Yes, it does come with the tow hook. The option is if you want to use it or not. ;) Please let us know if you have any other questions.
Thank you,
Dr. Design
D3 Cadillac
