: Passenger side window issues
05-12-11, 05:40 AM
I seem to be having some issues with my passengers side window. I reset the one touch and it stays up and goes down without a problem.
But it seems as though my passenger side window allows too much wind noise. There isnt actually any wind that goes in the car but the noise is bothering me..
Is there a quick simple fix for this? or do I have to take it to the dealership??
I am out of warranty and everything would be paid out of pocket...
thanks, and I also tried searching and didnt have any luck..
05-12-11, 04:19 PM
When you say you reset the "one-touch", do you mean you re-indexed the windows?
Take a (thick) sheet of paper and place it across the top of the glass. Close the door and pull the paper back and forth across the sealing surface looking for any areas that seem to be looser than others. Compare this to the driver's side door glass which seems okay. Inspect the trim pieces around the window glass. The problem may be with the alignment of your passenger side quarter glass. There are adjustment nuts if it's out of position.
