: GTO spares as front runners
Junkie414
05-10-11, 11:02 PM
A lot of vette guys do it on C6's. Do you guys think something like this would work on the CTS-V's?
baabootoo
05-10-11, 11:58 PM
I never would which is why I carry a full-size spare. I want to be able to drive "normal" even after a flat. There are only two types of people that drive on peanut spares; criminals and drug dealers............, and it's always in rental cars. :)
Caddy Wagon
05-11-11, 12:10 AM
I believe he is referring to using them as front runners at the drag strip, not for street use.
Junkie414
05-11-11, 12:11 AM
Exactly.
http://www.google.com/imgres?imgurl=http://www.ls1tech.com/forums/attachments/corvette-performance/257728d1286486298-mounting-16-et-streets-c5-cheap3.jpg&imgrefurl=http://www.ls1tech.com/forums/corvette-performance/1339108-mounting-16-et-streets-c5.html&usg=__bllKv5s5-N4hZ1ZufcZdSME-J4w=&h=450&w=600&sz=77&hl=en&start=0&sig2=rN_cPy0QhvFojtfLhiLylw&zoom=1&tbnid=AFE2BUfs69ObaM:&tbnh=129&tbnw=172&ei=YwzKTZ2CKYLW0QHR07GTCQ&prev=/search%3Fq%3DCorvette%2Bon%2BGTO%2Bfront%2Brunners %26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1280%26bih%3D 563%26tbm%3Disch&um=1&itbs=1&iact=hc&vpx=125&vpy=83&dur=212&hovh=194&hovw=259&tx=114&ty=108&page=1&ndsp=18&ved=1t:429,r:0,s:0
gonfishin
05-11-11, 05:43 AM
I would be interested in knowing if they would fit as well.
EVIL_C5
05-11-11, 09:56 AM
the problem is the speed rating on those donut tires. I really doubt they are meant to go 125 plus mph.....
I saw LPE has a custom drag pack on their ZR1 with skinny fronts, but im sure it aint cheap by any means....
serturbo
05-11-11, 12:17 PM
I think most sane people change out the donut tires... but there are idiots out there. LOL
EVIL_C5
05-11-11, 12:46 PM
i didnt know what size the rims were and what size there are for choices to replace them with.....
serturbo
05-11-11, 03:23 PM
Depending on the size, there are options. Looks like they may be 17s. There are both radial and bias tires available.
Domsz06
05-11-11, 03:27 PM
would the calipers clear?
thebigjimsho
05-11-11, 03:37 PM
what are calipers?
Junkie414
05-11-11, 04:26 PM
Thats my main concern. Going to order some 1" bolt on spacers and see where clearance sits after that. If we could have a small/light weight drag front it would help a lot
Me Wanna A V
05-11-11, 05:45 PM
You should contact Bogart Racing Wheels and see if they can make a front wheel for the V.
Back when I had my Cobra, I had Bogarts (15X3.5 front 15X10 rear) as they were the only racing wheels that actually incorporated the spacer as part of the wheel in order to clear the large Cobra calipers.
http://www.bogartracingwheels.net/
serturbo
05-11-11, 05:54 PM
It'll depend on how much weight is actually shed from the vehicle. When I still had my 370Z, one of the forum members were planning on using spare tire wheels as front runners. Iirc, it saved about 20 lbs per side. I guess that makes a difference in a car weighing only 3300, but aren't ours in excess of 4200.
darvish
05-11-11, 11:29 PM
I am guessing with the sedan the spare tire well is not home to the sub-woofer.
