: 1989 cadillac Brougham fuel filter
05-10-11, 10:57 PM
Where is the fuel filter located on a 89' Brougham and what would be the best way to get to it?????
05-10-11, 11:04 PM
if it's carb'ed like my 87...fuel filter is located in the fuel inlet on the front of the carb. you need 2 wrenches to get it off.
05-10-11, 11:29 PM
You need use two wrenches so the fuel line does not twist. When you get it off, the filer is spring loaded and will pop out. You need to make sure you get the spring in right or the new filter will not fit correctly (the replacement is a little longer than the original).
05-10-11, 11:49 PM
so is it in or around the carborator????
05-11-11, 12:01 AM
It's in the carberator at the end of the fuel line. The part the line goes into screws out. Put the new filter and parts back in the same way the old ones came out.
05-11-11, 01:07 PM
just look at the front of the carb. follow the fuel line till it enters the carb and where it screws into the carb is where the fuel filter is. you need to wrenches like everyone else said and you should put a couple rags down cause your going to spill fuel!!! pretty easy takes like 10 min unless your line is seized onto the carb.
cadillac kevin
05-11-11, 01:33 PM
and dont under any circumstances get the cheapo plastic fuel filter. they can melt and catch fire.
05-11-11, 01:49 PM
alright you all stay close im about to try and change it.
05-11-11, 02:16 PM
welll me and a buddy of mine just tried it we had 2 wrenches/pliers and we almost got it but the fuel line looked like it was going to knot up..... what now????
05-11-11, 02:40 PM
the point behind using two wrenches is so the fuel line doesn't turn to prevent it from "knotting up"
you put one wrench on the fuel line and one on the large inlet nut. I unscrew the line from the inlet nut first to free it up. You will probably have a little bit of gas come out of it, but only wahtever was left in the end of the line.
After that, you take off the large inlet nut and inside that inlet nut is your fuel filter.
05-11-11, 02:44 PM
we had them both on but he let it lose and it bent a little bit but did not knot up.... i have a mechanic (uncle coming to look at it and we gonna do it in about a hour. but i'm now worried about the fuel line.... u think i willl need a new one....???
05-11-11, 03:55 PM
If it isn't restricted and didn't split you should be ok. you may want to spray the nuts down with some WD40 or simliar if they are hard to turn.
