: catera problems help!!!!!!!!!!!
chrisrg
05-10-11, 09:39 AM
my shift light indicator wont come on when i have the headlights on...headlights have to be off for shift light to turn on....anybody have an idea how to fix that?
also foglights wont turn on...i did everything theyve mention here but still nothing....any ideas?
kaustein
05-11-11, 12:53 AM
I had the fog light issue too. Replaced the switch unit and worked for while. But I said the hell with it. The car is an electrical nightmare. Wait until the sunroof opens for no apparent reason...when it is raining.
hgqguy
05-12-11, 10:46 PM
did u check the k134 relay? that can cause fog lights to not work.
Sounds like overlaoded fuse that may have a short.
chrisrg
05-13-11, 12:46 AM
how do I find the ooverloaded fuse and the k134 is the gray box right?if yes I have already replaced it...and still nothing.
chrisrg
05-13-11, 12:49 AM
how do you replace da switch
kaustein
05-13-11, 10:44 PM
The headlight unit is square. If you slide a thin piece of metal at the 9 and 3 o'clock position, and then just pull, the unit will just come out. Once out, you will see how it installs. Make sure the new switch is the same year group as the old one. 97-99 and/or 00-01.
chrisrg
05-14-11, 01:59 AM
ok tnkz
