: Who has the best deal on an upper pulley?
Junkie414
05-09-11, 11:45 PM
So far mods are 10" lower, intake, tune, ID850's and its doing 570/590 at the wheels. Thinking upper pulley might be my next step, I see a lot of people also go with a ported snout. Is that needed for this mod or does it just optimize it? What size are you guys running and where are ya buying? Id like to make 600+ through stock manifolds and exhaust.
whytediamond
05-09-11, 11:53 PM
Most are running a 2.55 upper but with a 10" lower that might be a bit extreme, the blower will be spinning crazy RPM. Wait4me has a good buy on them, I think 100 bucks or so. Maybe try thinking of another way to hit 600.....maybe a cam? Someone else with more knowledge will chime in im sure. If you do the upper pulley you do not have to port the snout but it helps a little. Hope that helps, best of luck in your 600HP quest.
Caddy Wagon
05-10-11, 12:03 AM
...Wait4me has a good buy on them, I think 100 bucks or so...
x2. It's about $200 by the time you get the belt and shipping, but I believe he has about the best price.
Junkie414
05-10-11, 12:07 AM
Thats cheap! But I didn't think about over spinning the blower. Whats the max boost you guys are seeing out of these things before they get way out of the efficiency range? I'm at 13.5-14ish right now
whytediamond
05-10-11, 12:17 AM
Thats a pretty good boost range now IMO. Stock rpm range is 16,900 and with just the 2.55 upper its up to 19,900 so just imagine with the 10" lower.....might be 23-24,000, too much if you ask me. I beleive some members reported a reduction in boost with a 9.5 lower and 2.55 upper cause the combo just didnt work well. I think the 9" lower with the upper works well but you might as well just leave the 10 on. I would call Jesse or one of the other vendors and get their opinion and they will get you to 600 as safely as possible.
PhxTriode
05-10-11, 12:24 AM
Anything past 22,000rpm your treading in frag territory.
With a 10" ring your about there, I have heard of someone running 2.55/9.55 combo but with only 3/8" between the intercooler brick and the lid it is likely to deadhead (lose boost and gain heat).
Go with a cam. ZR1 cams are cheap. Drumstix is using about the same blower speed with that cam and a custom ported blower/lid building awesome power (granted his tune).
DrumStix
05-10-11, 07:19 AM
I only have a 8.6 lower and blower speed is about 22,000. I also thinking slapping in a small cam and some springs is a good idea. You'll also need the three bolt upper sprocket if you go with the LS9 cam. It's a couple bux.
