: driver door lock switch light??
Billd0957
05-04-11, 02:17 PM
The passenger door lock switch lights up but the drivers side does not.
The switch does work but just does not light up. Is this wrong?
chazglenn3
05-04-11, 05:02 PM
The bulb has burned out. Easier to replace the switch than the bulb. They can be had on rockauto.com for about $20.
ddalder
05-05-11, 01:04 AM
These are not bulbs, they are LED's.
ddalder
05-05-11, 01:05 AM
Is it safe to assume the door opens correctly from the outside when you pull the handle (even when "locked")?
chazglenn3
05-05-11, 08:39 AM
Interesting. Both of the lights stopped working in my sunroof switches. I just replaced the entire console with a replacement from eBay. Are they also LED's? If so, I'm surprised they quit working already.
ddalder
05-05-11, 09:14 AM
No, my mistake. I originally read this as meaning the red light on top of the door panel was not working on the drivers side. You're correct, those will be bulbs.
Billd0957
05-05-11, 09:57 AM
Thank you all for the replies, looks like I will be replacing the switch
rics8
05-31-11, 11:53 AM
so how would you change it?
mine went out. 2008 sts
EChas3
05-31-11, 02:58 PM
There's a good pair of threads that contain links to each other. Check back a few weeks or use a search.
chazglenn3
05-31-11, 09:13 PM
The door panel has to come off. If you plan to work on these cars yourself, I would highly recommend getting at least the DVD of the factory service manual. I prefer the real paper manuals, myself.
rics8
05-31-11, 09:24 PM
so to change that one bulb for that lock/unlock button you need to take off the door panel and not the handle area were it resides?
chazglenn3
05-31-11, 09:29 PM
Just checked the manual...you are correct. The bezel just pops off. I was thinking about the window switches.
rics8
06-01-11, 09:46 AM
you guys are champs :) i love this forum.. caddy for life.
