: High Performance Sway Bar Systems (In Stock)
Dr. Design
05-02-11, 09:29 PM
D3 Competition Sway Bar Kit
Application: 08+ CTS Coupe/Sedan/Wagon 09+ CTS-V Coupe/Sedan/Wagon
Part # D3.2101120
MSRP* ($USD) $895 – $695 Introductory offer for a limited time only!
Application: CTS-V Coupe/Sedan/Wagon MY 2009+
Line Item: D3 CTS-V Sway Bar Kit, incl. Front + Rear Sway Bar
Description: We would attribute the D3 Sway Bar Kit + the D3 Competition Springs in aiding HeaVyweight Racing take 2nd place in overall points in the 2010 Redline Time Attack Circuit. Congrats to Team HeaVyweight Racing!
Developed on the Race Track the D3 Sway bar kit has been engineered to allow for the maximum amount of roll resistance while still maintaining quality drive characteristics.
The D3 Sway Bars have been designed to provide an extraordinarily flat driving experience when pushing hard through the corners. The D3 anti-roll bar works to further reduce body roll by tying together the right and left sides of the suspension. This essentially lends more wheel rate from the side that’s in droop to the side that’s being compressed. More roll stiffness means less body “lean”, and the tires stay flatter on the pavement (with more tire contact). The result is more grip and added driver control!
* Flat Cornering
* Dramatically decrease understeer
* Multiple user settings and adjustments
* Excellent vehicle rotation
* Less body roll means more traction
* Faster cornering speeds
* Increased driver confidence
We strongly consider our Competition Sway Bars as a Must Have for any serious track-prepped CTS-V.
Notes: Includes replacement bushings. Uses OEM 14mm end link bolt.
Order Info: For additional information, current pricing and promotions, or to order contact your /D3/ representative at 562-595-8518 or sales@d3rd.com
Please let us know if there are any questions or visit http://www.d3cadillac.com/products/d3swaybar09ctsv
Thank you,
Dr. Design
D3 Cadillac
05-02-11, 11:02 PM
I'm pretty sure the back goes in easy but what needs to be done to install the front?
05-03-11, 10:00 AM
What is the weight and thickness difference over stock ?
Dr. Design
05-03-11, 06:11 PM
The back is very straight forward. As for the front sway bar you basically just need to angle the front cradle down towards the ground and snake it through. There is just enough room to get it out and the new bar in without any major headaches.
Thank you,
Dr. Design
D3 Cadillac
Dr. Design
05-03-11, 07:09 PM
The factory front sway is 29mm
The D3 front bar is 35.3mm dia
The factory rear sway is 25.4mm
The D3 rear bar is 27mm dia solid
OEM front bar weight = 10.7 lbs.
D3 front bar weight = 16.4 lbs.
OEM rear bar weight = 7.6 lbs.
D3 rear bar weight = 16.0 lbs.
Thank you,
Dr. Design
D3 Cadillac
