: 10" pulley psi
Bookinctsv
05-02-11, 05:42 PM
hello guys i will be getting a 10" pulley from jesse at wait4me and i just wanted to know how much boost will it be adding me and other mods did you guys put along with it. i also haver been trying to get ahold of jesse but he still has not contacted me back so if any of you fella know him personally please let him know I want to get the 10" pulley. Jesse if you read this please pm me back!
kirbyCTSV
05-02-11, 06:59 PM
10.0-----------2.95--------3.39--------14 psi (change crank pulley)
10.0-----------2.55--------3.92--------18 psi (change both pulleys)
i think this is what u looking for
shade
05-02-11, 07:12 PM
Better get a heat exchanger and think about some injectors
hemi2LS
05-02-11, 08:17 PM
Definitely get bigger injectors, don't even look at 60lbs, go ID850 off the bat. I'm at 13.5 psi with my setup but I'm also maxed out on injectors
aj660
05-02-11, 08:49 PM
14psi sounds spot-on.. Of course , if you go with 10" lower, then you must leave the upper stock.
I have 10" lower, heat exchanger, injectors, cat-back exhaust, new era cai, ported-blower, mild cam, and I'm at 16psi. I need headers to lower my boost.
Mike TexaSS
05-02-11, 09:01 PM
I make 14 psi with a 9.55" lower. Id say a 10" should be good for 15 psi.
But you better upgrade the bottleneck stock exhaust!
DrumStix
05-02-11, 09:20 PM
Just order it direct from Metco then.
PhxTriode
05-02-11, 09:35 PM
+1 on the ID 850's
wait4me
05-02-11, 09:38 PM
Sorry have been working a ton here and not alot of time for phones. Call me in the morning, ill be answering them till around 12pm, Hannah has been answering every single call though, so who ever is calling should be getting thru.... She can help you out as well. I have them in stock.
Somefun
05-02-11, 09:57 PM
14 with headers and ported snout but better get the 850's!!!
Domsz06
05-02-11, 10:08 PM
He doesn't need the huge ID850's for just a 10" pulley. The 60's will be just fine up to 650 and change, and if he is not using a cam he will not touch 650.
If you have money to burn then swoop up on those ID's, but if your just looking around 600 get some 60's. Injectors are a HUGE HOT TOPIC on here. Best bet is to search and forum your own opinion.
Bookinctsv
05-02-11, 10:24 PM
Thanks for all of the responses guys. i already got a heat exchanger, d3 82lb injectors, full kooks exhaust, intake, kenne bell boostapump, spark plugs and wires. If anyone can tell me opinions on the d3 injectors please let me know.?
Domsz06
05-02-11, 10:35 PM
some tuners have an issue tuning them is all I have heard. If you get a tuner that can tune them your solid. I don't have any personal experience just heard from a vendor on here. Get a hold of Clifford, he can help.
Dr.Buzz
05-03-11, 07:04 AM
I have a ported blower, heads,headers and different pipes running back to stock mufflers and am at 13.5 psi.
hemi2LS
05-03-11, 09:49 AM
I dont know if he wont need to go bigger only talking from my own setup 120% IDC on 60lbs, but you are right I shouldnt have only mentioned ID850, because he can also go modified LS9. There are other options out there, just choose the ones your tuner is comfortable with.
Bookinctsv
05-04-11, 11:48 AM
i Just hope my tuner can take hold of the 82lbs from D3. but if those injectors dont start working properly are you guys recoomending the ID850's?
