: Installed D3 springs, not low enough!
05-02-11, 01:38 PM
Well these things aren't low enough. The only issue is, later on I plan on upgraded the sway bars and giving the brakes some love so I can have some fun on a road course and drag strip. Basically if I were to cut 1/4 coil out of the fronts and rears is that going to effect me in a very negative way on the street/track or is that a small enough amount that it should be ok?
05-02-11, 02:34 PM
In all the other posts, others have done this on the Eibachs also. I would try it out first, to make sure you aren't degrading the performance. There aren't many people that can reach the limits of the stock suspension, let alone modified.
05-03-11, 10:01 AM
Let the spring settle for 500-1000 miles before you decide to cut
