View Full Version : 368 Help?
Monty Prescott
05-01-11, 10:17 PM
Hello Everyone
I am restoring a 1961 Cadillac hearse and turning it into an Ecto-1.
I have a Cadillac 368 that I pulled from a 1981 Cadillac hearse that I'm planing to put into the car.
I'm not looking to put any Performance into the motor I'm just looking to dress it up and make it look good for car shows ect. I would like to put an Edelbrock Intake and valve covers and other fancy chrome parts ect on the motor.
What parts are interchangeable between 500, 472, 425 for the 368
any help would be greatly appreciated.
05-01-11, 11:21 PM
The 368 is really not that good of a choice...140 or 150 HP... not great on gas mileage.... If I was doing it , I would go with a 350 ... I love the lt1 like in my 94 and 95FWB's... If you did not want to mess with all the wires there are carb manifolds for it... This motor will give you twice as much power and better gas mileage than the 368... The 368 is only one and a half notches above the slug olds 307...one can't get out of its own way and the other can't get in its own way...that 368 is nowhere as good as the 390 that came in the 61.....
05-02-11, 08:27 PM
I'm afraid drmenard is right. There are not a lot of options for the 368 for performance or dress-up.The best you could do is paint it pretty and keep the hood closed, if possible. There were aftermarket and factory options for the 390, as it was concidered a performance engine..
05-24-11, 04:57 PM
1981 also had the 8-6-4- engine.
05-24-11, 05:24 PM
I went on a long trip about 3 years ago with my cdv with a 368, 64,000 miles on the engine, the only time it bogged down was going up a long grade, the top end torque is poor, but it made it, 99 % of the time I am quite happy with it, it all depends what type of driving you will be doing, around town and on the hi-way it's fine for me.
05-27-11, 06:25 AM
Contrary to what others have said, the 368 is a worthy engine and directly related to the 472/500/425 engine family. It has but one fault in that in its factory state of tune it is rather "soft" and not very responsive. My question is why you'd want to replace the '61's 390 with it. No matter, the 368 CAN come alive and if you're pushing that kind of weight, you will need some help. Architecturally, it is not that much different from the others in the engine family. 1981 versions have the Eaton Corporation's Variable Displacement system and this can be a problem. From 1982 thru 1984 the 368 was used exclusively on the Limousine and Commercial Chassis vehicles, being discontinued with those cars at the end of the 1984 model year.
There's a website, 500cid.com that sells performance parts. You will need to wake the 368 up if you intend to use it in that vehicle. You will also need a THM 400 or 700R-4 transmission as the old 4 speed hydramatic in the 61 won't work with it.
