: The car saga continues.
ga_etc
04-28-11, 09:07 PM
A guy I know wanted the Thunderbird so bad he couldn't see straight, so I sold it to him Tuesday night. I let it go for $1,500 just to be done with it. The head gasket was blown and there was a tick in the motor. Not sure if it was from the coolant getting sucked into the motor or if something else was going on. Whatever the case was, it's gone now. In it's place now sits a 1996 Ford Explorer with the 302. It needs a through, and I do mean through scrubbing. I've already washed it twice at the car was and still needs to be gone over again. And the interior is worse than the exterior was. It's in good shape inside, though, underneath the filth.
The truck isn't the nicest looking thing on the road, but it runs great and has ice cold A/C. It rides and drives good, and has pretty damn comfortable seats to be a Ford.
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110428_192158.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110428_192243.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110428_192921.jpg
Not exactly what I wanted, but it'll work. I can put a little money into it and make it look a lot better. For now though it's something I don't have to be OCD over and will get me where I need to go. I think it's worth the $1,400 I gave for it.
hueterm
04-28-11, 09:19 PM
You're better off w/this than that RMW. The parts on this will be much easier to find, and it's cheaper.
ltdltc
04-28-11, 09:32 PM
This generation Explorer was nice even with the tire fiasco. http://www.explorerforum.com/forums/ -> is the place for all your DIY needs. To bad the 302 on those trucks have very small restrictive exhaust headers.
Stingroo
04-28-11, 10:38 PM
He has a RM Sedan, not wagon.
Looks pretty decent actually. Well bought.
hueterm
04-28-11, 10:43 PM
I know. He wanted a '91 RMW, but it was too much money and it wasn't an LT1.
ben.gators
04-28-11, 10:45 PM
Nice, A great car for 1400$! How many miles on the clock?
Stingroo
04-28-11, 11:04 PM
91 = fail. 305 only.
Easy to work on though, and definitely a slew of cheap parts.... but the slowness would irritate me.
Also: That Explorer has uncommonly decent looking seats. Weird.
hueterm
04-29-11, 12:13 AM
You're not kidding, though, about it being dirty... You need to get Rick to disassemble it for you like he did that 528 where the dirt kept leeching out of the carpet...
ga_etc
04-29-11, 12:14 AM
I'll take better pics of the interior when I get it cleaned up. That's as close as I wanted to get with the camera because it's disgusting inside. He kept the maintenance up on the truck and didn't beat it up, but detailing was not high on his list of priorities. All of the seats are in good shape though. No rips in the leather and just normal wear for the age and mileage.
Tomorrow I'll transfer my tag and insurance over, scrub a layer or two of filth off the interior, and try to track down a master window switch.
Ben, it has 149,6XX on it.
gdwriter
04-29-11, 12:17 AM
Not bad for $1,400. Still a shame about the turd-bird.
Jesda
04-29-11, 12:21 AM
Nice! You got the 302! Should be much less finicky than the Cologne V6. I like the full center console and camel leather too. Congrats!
ga_etc
04-29-11, 12:44 AM
Thanks. It's loaded up like a Limited without the AWD and no sunroof. It has the overhead display with the outside temp and compass too.
It's far from perfect but it's a solid old truck. A little work and elbow grease will go a long way.
cadillac kevin
04-29-11, 12:57 AM
you did pretty good for $1400.
black out the back windows and repaint the black applique on the pillars, realign the front sheetmetal, and you'll have a sharp truck.
Aron9000
04-29-11, 01:49 AM
That's pretty damn nice for $1400. Is it 2wd or 4wd?? Seats are nice as well, usually on old beater cars like this the leather is ripped to shreds. Are they comfortable? Cause they sure do have enough adjustments to look comfortable.
ga_etc
04-29-11, 02:04 AM
2 wheel drive. And the seats are pretty good. Both front seats have 8 way power adjustments with power adjustable bolsters and lumbar. The recliner is manual though. I don't think the bolsters or lumbar on the driver seat work, but that's a non-issue.
greencadillacmatt
04-29-11, 02:09 AM
We had a 1996 Explorer XLT. It had the 4.0 V6, leather, sunroof, etc. I REALLY miss it, it was an amazing rig. Never broke down, never got stuck, and what little did break was DIRT cheap to fix. It had amazingly comfortable seats. Ours was dark red with a light grey interior. Well played, Austin.
thebigjimsho
04-29-11, 10:21 AM
Hope the Exploder works better than the Thunderturd...
EcSTSatic
04-29-11, 11:03 AM
Just found out about the T-Coupe. A blown headgasket is unusual unless it was overboosted. Those engines are solid - cast iron block and head.
Sounds like you wanted an Explorer anyway.
ga_etc
04-29-11, 03:32 PM
He was pushing 25-30 lbs of boost at one point apparently. I like that the Explorer has the 302 in it, which is a pretty damn rock solid motor, and I like the cargo capacity and versatility of it.
ryannel2003
04-29-11, 03:53 PM
Great trucks. My aunt had a '00 XLS that went to 190k before it needed a transmission. That's about the only thing you have to look out for on these, otherwise they're rock solid.
ben.gators
04-29-11, 05:01 PM
Dude, please don't call it "pretty damn rock solid motor"... When you call it "pretty damn rock solid motor", I feel like it is going to happen again!... :D
Sevillian273
04-29-11, 06:14 PM
Does it smoke on startup? My 302 started to do that around 140K, but then again, I beat the snot out of it. When I took it apart there was no visible cylinder wear and I could still see the honing marks. However, the timing chain was wildly stretched:
http://i106.photobucket.com/albums/m280/merc892003/12-07-10_1646.jpg
Yours should have an updated set though hopefully minus the plastic cam gear...
I had that rig for 8 years and all I ever had to do was a water pump and an ignition module. Epic reliability from the oval.
Destroyer
04-29-11, 11:07 PM
I never really liked Exploders but I would have taken that Turbo coupe off your hands for more money than you got for it. I would have put a 347 small block in it. Wish I would have known it was for sale..........:nono:
hueterm
04-30-11, 12:59 AM
OMG...Austin is going to freak...
drewsdeville
04-30-11, 01:03 AM
Valve stem seals :thumbsup: Typical on Ford V8's for a decade or two there, including the early 4.6's. Finally revised in 1996.
ga_etc
04-30-11, 01:28 AM
Nope, no smoke. It's surprisingly quiet running for a 302. It sounds really nice when it get into the gas though.
If I had known you were interested in it I would have sold it to you in a heartbeat. It was a really, REALLY, clean car. I told the guy I sold it to he was getting a hell of a deal for $1500 and he knew it was the truth.
I~LUV~Caddys8792
05-01-11, 09:40 AM
Good deal Austin! Looks like a heck of a car for $1400 and once you've got it cleaned up to your liking, I'm sure you'll enjoy it for a long time.
ga_etc
05-01-11, 08:08 PM
I need to go out and take a couple of pics since I got it cleaned up a little. I think I will do that. Stay tuned...
ga_etc
05-01-11, 08:48 PM
It's not the greatest looking thing, but I like driving it for some reason.
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192136.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192154.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192208.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192234.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192321.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192333.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192355.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192422.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192440.jpg
http://i685.photobucket.com/albums/vv220/austin99etc/IMG_20110501_192812.jpg
orconn
05-01-11, 09:02 PM
Bravo! You brought it back from cantagion!
Good job, I hope it serves you well!
Stingroo
05-01-11, 09:17 PM
Looks quite presentable honestly. Not bad for $1400 considering how much anything that's a truck or SUV costs here in the South. lol
hueterm
05-01-11, 09:23 PM
Looks pretty good, Austin! The interior is really in good shape -- the only thing awry is the chunk out of the armrest. The seats do look comfortable.
You could keep that as a beater for years even after you get a new car in the future.
ga_etc
05-01-11, 09:48 PM
It seems to be a decent old truck. I was told by a mechanic that I could part the truck out and get more out of it than my purchase price. The motor consists of the block from a '96 F150 but the heads and intake are from the '95 Mustang GT, also referred to as GT40 heads.
ryannel2003
05-01-11, 10:10 PM
It really doesn't look bad at all, especially for $1400. Fix that front bumper and the fender and polish it up and it will be a really nice SUV for many years to come. I'm sure it sucks down gas like nobodies business though...
I~LUV~Caddys8792
05-01-11, 10:46 PM
When I was researching these midsized SUV's last winter, I found out that the Explorer was the best riding & most comfortable and had the best assembled interior. The Grand Cherokee was the best offroad and the Jeep's 318 was the snappiest of the engines and I don't remember what the GM's suv's strong points were...
ben.gators
05-01-11, 11:04 PM
Great job!.... The other blemish that you can easily fix for cheap is the headlights.... Buy a 3M headlight restoration kit and give those faded lenses a new life. It will improve the look of the car a lot.
ga_etc
05-01-11, 11:51 PM
I'll find out how bad it is on gas soon. Just filled it up. With regular at $3.69 a gallon it held $68 worth. Ugh. But in all actuality, that's what it would have taken to fill the Eldorado with premium.
I~LUV~Caddys8792
05-02-11, 12:00 AM
I don't think that the Explorer will be much worse than the Eldorado on gas around town....they'll probably both get 16-17mpg in town, but on the highway you'll see the big difference...19mpg v. 24....
ga_etc
05-02-11, 12:20 AM
By the time the Eldorado left the driveway (Chicago trip) it wasn't getting but about 22 on the interstate.
Aron9000
05-02-11, 02:07 AM
That Explorer will probably get more like 13-14 in town and 16-17 highway.
ga_etc
05-02-11, 02:53 AM
I'm keeping my fingers crossed for 16-17. Don't jinx me. I can't afford to come to Nashville and find you to kick your butt right now. :P
I~LUV~Caddys8792
05-02-11, 08:34 AM
13-14? That bad huh?
Destroyer
05-02-11, 08:51 PM
If I had known you were interested in it I would have sold it to you in a heartbeat. It was a really, REALLY, clean car. I told the guy I sold it to he was getting a hell of a deal for $1500 and he knew it was the truth.Thanks man. If it was as clean or even nearly as clean as it looked it would have made a good V8 candidate. I never really liked the 2.3 motor as I found to rough and abrasive. I've looked for them in the past but they are usually in terrible condition WHEN you can find one. They are getting hard to find!
ga_etc
05-02-11, 11:58 PM
Yeah, they really are. And the car really was in as good of shape as it looked in the pictures. You're absolutely right about the 2.3 too. It's about as far from smooth and refined as you can get in a 4 cylinder, at least the old ones like that. When the turbo came on and it put you in your seat the last thing you really cared about was how refined the motor was though lol.
There's this one still on CL that's already had a 302 put in it, but it's an automatic and a little tired looking. http://chattanooga.craigslist.org/cto/2330112222.html
ga_etc
05-03-11, 12:18 AM
I think when I have some money to put into the truck, I want to dress it up a little and make it sportier. It's just 2wd so it's stupid to jack it up, so I think it could stand to sit a little lower. I like how this one is set up.
http://www.explorerforum.com/photopost/data/502/7134detailed4.jpg
I~LUV~Caddys8792
05-03-11, 12:37 AM
What sorta mods are out there for the five-liter? Is it gonna have a bunch of stuff available like the Mustang 5.0's or nothing at all like the F-150's 5.0?
ga_etc
05-03-11, 12:55 AM
Haven't looked honestly.
cadillac kevin
05-03-11, 01:03 AM
apparently opening the hood magically turns the car from white into red. wish my car did that.
Destroyer
05-04-11, 12:02 AM
What sorta mods are out there for the five-liter? Is it gonna have a bunch of stuff available like the Mustang 5.0's or nothing at all like the F-150's 5.0?If I'm not mistaking the Explorer's had the GT-40 heads and were H.O. motors meaning they were more powerful than a stock Mustang with a 5.0 but not by much. Still, any mods you can do to a Mustang you can do to a 5.0 Explorer. Question is, is it worth it? It would take a ton of mods just to make it as fast as a stock 5.0 Mustang. I say slap headers and dual exhaust w/Flowmaster mufflers and just make it a cool sounding cruiser.
Jesda
05-04-11, 12:06 AM
If there are mods to choose from, go for the ones that contribute to greater fuel economy. I removed my roof rack -- guys on the forum say thats good for a half mpg on the highway.
orconn
05-04-11, 12:25 AM
If you want better mileage inn "Duckyy" you might try removing the beagle, his ears are probably costing your 5 mpg!
ga_etc
05-04-11, 01:14 AM
Right now the CEL is on with codes showing for the EGR valve and camshaft position sensor. I don't know for sure if those are effecting my gas mileage, but if mods are done, it will be to help with the MPGs. Intake and exhaust are probably the most beneficial things to do, plus they make it sound better anyway, so it's win-win. Stock the truck is rated at 210HP and 280TQ. I believe the torque numbers too. It has a full posi rear end and street tires on it, no A/Ts. I went to a friend's house earlier and it's been raining all day. This thing will get your attention in a hurry. A little too enthusiastic with your right foot and the rear will step out before you know it.
A little extra oomph and a lower center of gravity and this thing could be all kinds of fun.
I~LUV~Caddys8792
05-04-11, 01:19 AM
Isn't it nice to have a V8 again? :cool2:
ga_etc
05-04-11, 01:28 AM
Oh yeah. It's being exceptionally thirsty right now though. I can't seem to keep my foot out of it.
ga_etc
05-04-11, 01:40 AM
Just ran the VIN on it. According to compnine it's a limited slip, but it sure acts like a full posi. It's also 3.73 geared.
Destroyer
05-04-11, 06:44 AM
Oh yeah. It's being exceptionally thirsty right now though. I can't seem to keep my foot out of it.That situation will worsen if you put a nice sounding exhaust on it. I know headers and dual exhaust work to get better mpg's but it never works that way for me as I feel the need to get on the vehicle more to hear it better. :cookoo:
Sevillian273
05-04-11, 10:09 AM
Stock mustang headers should be a direct fit. And cheap too. Alot of the go-fast goodies for that are what the mustang guys are trying to get rid of.
ga_etc
05-04-11, 12:59 PM
Yeah, I know lol. It's a wonder the truck can breathe anyway. I think it's got 3 or 4 cats on it.
Sevillian273
05-04-11, 01:04 PM
Should have 2 small ones on each side... These motors sound pretty tame with the cats intact and a muffler delete.
I~LUV~Caddys8792
05-04-11, 10:50 PM
I can't wait until I'm back behind the wheel of something V-8 powered as well....should be by the end of the week...
Destroyer
05-04-11, 11:07 PM
I can't wait until I'm back behind the wheel of something V-8 powered as well....should be by the end of the week...Do tell.............:suspense:
I~LUV~Caddys8792
05-05-11, 12:05 AM
Remember that "let's talk full sized vans" thread I had last week?? My boss is looking at a lot of stuff...he told me I should have something by the end of the week... I'm hoping for a nice Econoline...
greencadillacmatt
05-05-11, 12:49 AM
^With shag carpeting and a porthole window on either side I hope.
hueterm
05-05-11, 01:15 AM
With a ratty sofa and a fake cast in the back, so he can go trolling around the trashier apartment complexes of St. Paul...
It rubs the lotion on its skin, or else it gets the hose again...
hueterm
05-05-11, 01:16 AM
God that was a good movie...seeing that in the theater was awesome...
I~LUV~Caddys8792
05-05-11, 01:16 AM
Bwahahahhahahhahahahah!!!!
hueterm
05-05-11, 01:18 AM
The problem is, if you found a 6' tall size 24 girl, or whatever Miss Catherine Martin was...she could kick yo' AZZ!
ga_etc
05-12-11, 07:51 PM
Since I changed the air filter on the Explorer (now it has a K&N) it's getting better mileage. My lead footedness still exists though. :D
Anyway, I know a couple of people were interested to I took a quick 0-60 video on the way home from work. Stare in awe of the awesomeness that is a 302 Exploder LOL.
http://www.youtube.com/watch?v=0skAmPrp8QQ
ben.gators
05-12-11, 07:58 PM
Nice nice, as said before you got a hell of deal for 1400$. By the way, there is a light in your dash, what is it for?
ga_etc
05-12-11, 08:09 PM
Check engine light. It's a Ford, they're not allowed to leave the factory without it on.
Sevillian273
05-12-11, 10:00 PM
What it meant to say was
Engine?
Check.
And off to the dealership!
thebigjimsho
05-12-11, 10:36 PM
He ain't just whislin' Dixie, folks...
ga_etc
05-12-11, 10:43 PM
http://www.youtube.com/watch?v=lh-EjQ7xAcE
ga_etc
05-14-11, 11:33 PM
I think the Explorer would look good in this color. I think it was strictly a Ranger color.
http://images.dealerrevs.com/pictures/15647423.jpg
Mandarin Orange Metallic
thebigjimsho
05-15-11, 12:19 AM
orange truck. you moonlighting with Roo?
ga_etc
05-15-11, 12:28 AM
No, I just like certain shades of orange too.
Stingroo
05-15-11, 02:46 AM
Everything needs moar orange.
EVERYTHING
I~LUV~Caddys8792
05-15-11, 09:30 AM
There's a guy in my area with a bright orange Buick Regal LS. It's the same style as mine, but without the supercharger. I keep wanting to take a picture of it and post it on here for Ray, but I keep forgetting when I do actually see it.
thebigjimsho
05-15-11, 02:29 PM
He iz stunned.
