: FYI for those changing to solid isolator
vseries
04-28-11, 08:35 PM
First off I must say I am glad I am doing this as my car has 19k on it and do not know what the shaft would look like at 50k. OK so as most cars with some mileage there was some oil sludge/vapor build up within the upper plenum so I decided to clean everything including the square orange gasket , I did not use any solvents just an old t-shirt. When I went to replace the gasket it had expanded and is completely unusable as it would not sit correctly within the lower manifold any longer. Now my car is apart for 2 days waiting for a replacement. SO for those of you planning to do this either get a replacement gasket ahead of time or DO not remove it from the lower manifold.
On another note the oil accumulation has led me thinking into install a catch can, what do you guys think :hmm:
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75128d1304033718-fyi-those-changing-solid-isolator-imag0168.jpg
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75127d1304033718-fyi-those-changing-solid-isolator-imag0182.jpg
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75124d1304033718-fyi-those-changing-solid-isolator-imag0171.jpg
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75123d1304033718-fyi-those-changing-solid-isolator-imag0169.jpg
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75126d1304033718-fyi-those-changing-solid-isolator-imag0173.jpg
http://www.cadillacforums.com/forums/attachments/cadillac-cts-v-series-forum-2009/75125d1304033718-fyi-those-changing-solid-isolator-imag0172.jpg
gonfishin
04-28-11, 11:01 PM
You know how I feel about the catch can. I must say that shaft is seriously worn.
Also, I love your threads! They are always helpful with pics too.
Thanks for taking the time to post up.
RapidRob
04-28-11, 11:20 PM
I've got one of Jesse's isolators, and I think this post has convinced me to get off my a** and install it sooner rather than later. That shaft looks really bad ... ! Thanks for this post X2.
Rob
markrn
04-29-11, 10:46 AM
Possible to get the part # and cost of the gasket? Thanks for any info Mark
Mike 09 V
04-29-11, 11:48 AM
Great pics. Remember the so called "shaft" is just a locating stud to keep the spring somewhat centered. It does not do any work. The 3 pins and the isolator transfer all the power.
The Tony Show
04-29-11, 01:36 PM
I embedded your images so people don't have to click the links. :thumbsup:
musclesbmf
04-29-11, 01:39 PM
I disagree that it's not usable. I just had my blower completely apart twice last weekend and while the gasket seemed to have expanded a bit, it will still tuck in nicely. You just have to work with it.
Mark
6speeder
04-29-11, 02:50 PM
You might try cooling it to make it shrink a little. Just don't let your wife find it in the fridge.
jamesdean65
04-29-11, 03:25 PM
You might try cooling it to make it shrink a little. Just don't let your wife find it in the fridge. I agree.
CTSV4now
04-29-11, 03:50 PM
Do you guys have to sneak mods behind the wife's back or something?
vseries
04-29-11, 04:56 PM
I think I'm gonna try the cooling method , car is down for another day and probably weekend as I am waiting for a gasket
The Tony Show
04-29-11, 06:09 PM
I thought every guy knew about "shrinkage" in the cold? :sneaky:
gonfishin
04-29-11, 06:15 PM
I had to spray mine with Nitrous to get it to fit. :)
PhxTriode
04-30-11, 02:48 PM
http://tapatalk.com/mu/4663c4a2-4b15-71cd.jpg
This is what mine looked like when it was pulled. Yet GM swears there is no issue with the design... Hmmmm
vseries
05-01-11, 12:09 PM
Thanks Curtis like yourself I try to contribute when I can :yup:
vseries
05-01-11, 12:20 PM
Yes you are correct and it is important for people to remember this as it may not be worth the trouble for some people but it was piece of mind for me
Mark
Not in this case, the gasket clearly expanded large enough it would have never sat correctly and I was not gonna risk trying to squash it in there not knowing if it would lay flat or not.
Orange square gasket known as "Isolator" in GM parts catalog :12612467
Green upper plenum lid gasket :12613457
markrn
05-01-11, 03:01 PM
Thank you sir : )
PremierJosh
05-01-11, 04:55 PM
Everyone I have done has been like that. Some take a little work to get it to stay in place but keep trying it will work.
