: intake on 79 deville
04-28-11, 12:38 AM
hi all, i'm putting a new intake gasket on my 79 deville. i wanted to check and see if others put a bead of high temp silicone on the rubber seals that bridge the surface between the heads front and back. also i put a dab of silicone on the intake bolts. any input would be appreciated. thanks
04-28-11, 10:48 AM
Some people dont even use the front and rear seals, they just put a thick bead of silicone. I also use silicone only. But if you do use the seals, you would put a dab at the ends of the seals where they meet the head.
