: One dash light is out
04-26-11, 06:42 PM
After replacing the K134 relay module I noticed that there appears to be a light out on the dash, the are around the 20 mph is not being lit up as well as everything else. Could I have accidentally unplugged a cord while I was changing the relay, is there a fuse, or is it likely the bulb just went out?
04-27-11, 08:56 AM
I'm assuming that everything on the instrument panel is working okay but just the area around the 20mph mark is darker than the rest. If so, its more than likely going to be a bad blub, otherwise if it was a fuse nothing would light up or work. If you going to go ahead and replace the bulb I recommend getting some LEDs its has a much cooler look. Regular bulbs are 194 and leds are t10. hope this helps.:thumbsup:
Guide on how to remove I.P.
04-27-11, 03:24 PM
Yes everything else works with just one little spot that isn't lit up. I'll look into that replacement. Thanks!
