: 2002 Northstar security
miwise
04-22-11, 09:56 AM
What components are responsible for the security system in an 02. Im swapping my 99 to a low milage 02 drivetrain.
Sent from my MB860 using Tapatalk
miwise
04-22-11, 10:08 AM
I have the entire harness bumper to bumper
RippyPartsDept
04-22-11, 10:10 AM
That's not going to be easy, if it's possible at all
miwise
04-22-11, 10:15 AM
Its possible.
miwise
04-22-11, 10:16 AM
Im determined
miwise
04-22-11, 10:19 AM
Even if I have to gut the entire car and replace every sensor. I just wanna know if anyone knows which components exactly are different and incompatible
RippyPartsDept
04-22-11, 10:30 AM
just about all of it
edit: they do take the same PF61 oil filter though
miwise
04-22-11, 10:34 AM
Will I need to swap radio? Or the memory modules? Etc
I guess im asking if I need to rip out the dash too. I will if need be
RippyPartsDept
04-22-11, 10:46 AM
as far as i know nothing is going to be compatible - you'll have to swap everything (like you said earlier)
miwise
04-22-11, 11:25 AM
Aj. If ur there did u have a chance to look at that diagram I sent u?
miwise
04-22-11, 03:17 PM
Im sorry. If u can cram a big ole Northstar n a fiero I don't think its a stretch to be able to do this. This seems minor in comparison
RippyPartsDept
04-22-11, 03:36 PM
i didn't say impossible... but imho not worth it... just get a 99 donor
miwise
04-22-11, 04:08 PM
My reason for going this rte is bc I've not found a powertrain for my car w less than 100000 mi. If imma spend 3000 or 4000 I want the entire powertrain and close to 50k miles. Getting info from ppl who have the knowledge tho is like trying to squeeze blood out of a turnip. Quite frustrating. Thankfully my uncle has a friend who crams northstars n fieros so he may help
RippyPartsDept
04-22-11, 04:13 PM
if you're going to spend that much why not just rebuild your current parts instead of hacking together a Frankenstein (because that's what a 2000+ powertrain in a -1999 body will be)
at least that way you will know exactly what you've got...
what assurances do you have that this 2000+ powertrain is in perfect condition?
and why are you doing this in the first place? do you have blown head gaskets? leaky lower block seals? p0741 tcc code?
miwise
04-22-11, 05:00 PM
I know the guy. And I don't want rebuilt. Factory only. My current engine has problems. Unrepairable
miwise
04-22-11, 05:06 PM
I'm doing it because I'm tired of messing with this engine and transmission. I want to start fresh
RippyPartsDept
04-22-11, 05:19 PM
1) getting it to fit is going to be a challenge
2) getting the modules to talk to each other will be a challenge
to me, #2 is more of a roadblock than #1
miwise
04-22-11, 05:38 PM
Fit should be easy. Im gonna just use trial and error since im on my own here pretty much. The 99 and 02 Sts are identical bodywise. They both seem to utilize class 2 serial data streams. I'll know more when I stretch out the 02 wiring harness. I can't afford a remanufactured one and my current tranny has 170000 on it. Seems to make sense to replace both.
RippyPartsDept
04-22-11, 06:00 PM
definitely replace both together if you do this
you're swapping the PCM too, right?
what about the cluster and radio?
miwise
04-22-11, 06:42 PM
Is the cluster different? If I must ill swap everything. Im going to swap as little as possible.
Oh. And yes I do have the pcm. Do I need to swap the radio too?
MoistCabbage
04-22-11, 07:52 PM
"1993-1999 and 2000+. You CANNOT under any circumstances bolt a 2000+ engine into a 99 or older body or vice-versa. It simply does not work. Too many differences, too many sensors changed and the holes to mount them. Many people have tried, and gone through all of the work to bolt it in and realize that 1) some things don't bolt up correctly, 2) the wiring won't connect and 3) it won't run."
Taken from this sticky: http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/199946-northstar-swaps-what-years-interchangeable-differences.html
miwise
04-22-11, 10:06 PM
First. This is a single engine swap and not referring to a complete powertrain conversion which is what I plan on doing. :) A lot of the MODULES from the 98 99 cars will indeed function in the 2000+ cars. The engine/pcm doesn't care when the body was manufactured. Only that it recieves the correct input. As long as the computer talks to the dash and suspension modules it should work. My question is how was the wiring changed bw the body control module and pcm.
