: EMERGENCY! I have an interview tomorrow and my Car (2000 Eldo) is down!
alake
04-19-11, 10:21 PM
Hello Everyone,
I have big problem. I have an interview tomorrow which is an hour drive away. I need my car running.
I was driving on the highway tonight giving my Eldo a little WOT (as I've been instructed to do every now and then. Started driving normally, about 75 mph using the cruise control. Then all of a sudden, I started hearing some rattling. I cut off the cruise, and I notice the rattling slowed down with my foot of the gas. It sped up the harder I hit the gas. Up and down, up and down as I hit and released the accelerator.
I stopped the car popped the hood and narrowed the rattling down to the intake manifold. The car will run but I'm scared to drive it and make something worse.
I ran the codes and got this:
P0340 - Camshaft Position (CMP) Sensor Circuit - History
P0341 - Camshaft Position (CMP) Sensor Performance - History
P0385 - Crankshaft Position (CKP) Sensor B Circuit - Current (I changed the CKP about 20K Miles ago)
P1617 - Engine Oil Level Switch Circuit - History
Anybody! Anywhere! Please give me some advice! I need this job.
94CaddyConcours
04-19-11, 10:34 PM
Did you try to tighten the intake manifold cover to spec?
alake
04-19-11, 10:44 PM
Honestly, I haven't done anything yet. It's late and it's raining out. I'm not a real grease head or anything, but I do know how to follow instructions pretty well. lol
But the intake looked pretty tight, looks like it hasn't been touched in an awful long time. It sounds like something inside is rotating and hitting inside. I can check the torque to make sure before I tear into it.
Ranger
04-19-11, 11:10 PM
Check the idler and tensioner pulley's. The bearings may be going bad. If so, you do not want to drive it like that.
alake
04-19-11, 11:34 PM
I changed both tensioner pulley's last summer. I'd say they are good.
But that idler may be a good idea. I noticed a slight bit of a RPM fluctuation at idle last week. I haven't had a chance to check up on it yet. Where is that located? How do I check for good or bad?
Ranger
04-19-11, 11:48 PM
The idler (#4) is just below the tensioner. Loosen the tensioner just enough to let the belt slip. If the noise goes away, you know it is something on that belt. Shut down and spin the pulley by hand to see if it is rough, noisy or loose.
http://www.compnine.com/largeimg/9901196M01-033.gif
alake
04-20-11, 12:07 AM
[QUOTE=Ranger;2567447]The idler (#4) is just below the tensioner. Loosen the tensioner just enough to let the belt slip. If the noise goes away, you know it is something on that belt. Shut down and spin the pulley by hand to see if it is rough, noisy or loose.
So, for my own education ............. if it "IS" something on that belt that's going bad.......... what am I hearing ticking and rattling under the intake manifold?
Ranger
04-20-11, 12:26 AM
The only thing under the manifold (if you are sure that's where it is coming from) is the starter and the only way that could make a clicking noise is if the pinion return spring broke and the pinion was hitting the flywheel and bouncing back and forth. Possible, but not very likely.
alake
04-20-11, 12:15 PM
I have been having some starting problems, but I deemed it due to that Camshaft posistion sensor I never changed. :(
I was reading some more threads today, and I saw one where this guy had a nut in there rattling around, but it didn't say what caused it to loosen up.
MoistCabbage
04-20-11, 03:29 PM
Is the noise rhythmic or random?
Ranger
04-20-11, 04:14 PM
A bad pinion return spring will make more noise when you turn right. That would allow the pinion to shift to the left and engage the spinning flywheel. A left turn would have just the opposite effect.
alake
04-20-11, 05:47 PM
random.
At idle, it'll be soft for a little while (almost down to nothing), then all of a sudden get really loud for a minute or so, then get soft again.
When driving, it was louder and faster with the amount of pressure i put on the accelerator. Very low and slow with my foot off completely. Very loud and fast with the throttle wide open.
Something is in there moving around.
alake
04-20-11, 05:52 PM
I have the fuel rails loose, and the manifold off now. I found a ton of leaves and crap under there, but nothing hard that should make the kind of noise I heard.
I took out the starter and looked under it, but found nothing but leaves and such there. I'm thinking of replacing the starter since I've been having stuttering starts anyway, and I already got it out.
alake
04-20-11, 05:53 PM
I drove my brother's car to the interview by the way, if anyone was wondering. :)
vincentm
04-20-11, 06:56 PM
New starter? Theyre quite expensive if you're having hard starts i'd check your battery connections first before investing in a new part, also have the battery tested
Ranger
04-20-11, 10:16 PM
:yeah:
The leaves are from some rodent taking up winter residence in there.
Submariner409
04-21-11, 03:15 PM
Check your starter flange bolts and electrical studs twice - no sense going back in there........
Remember: The bolt torque for the intake manifold bolts is 89 in/lb. Only about 7.5 ft/lb. Be careful. Tighten the bolts in an outward spiral from the center two bolts in 3 steps - don't apply full torque all at once. Smear a drop of engine oil on each injector's O-rings. It will make dropping the fuel rail in much easier. When it's all back together, turn the key ON for 5 seconds, off for 30. Do this 3 times to prime the fuel system and check for leaks: the rail will hold 40 psi for hours if all's well.
alake
04-30-11, 11:38 PM
I guess I should've checked my starter bolts thrice....... I'm still having issues.
Pulled the starter out (since I had everything open anyway) and had it checked at Autozone. Checked out fine.
Buttoned everything back up. Everything powered up fine. Did the fuel system prime procedure per Sub above (thanks Sub).
Ran the codes.
Felt pretty good so I tried to fire it up. Got 1 churn out of the starter and the whole Electrical system went dead! No power anywhere at all. Pulled the battery connections, checked and cleaned the terminals. Stopped for a beer. Came back and reconnected the terminals. Power was back! Sweet!
Ran the codes again. Nothing new. Tried to start her up....... 1 churn and the Electrical system went dead again. I'm thinking the car is sensing something, and shutting me down before I break something. Maybe a missed ground somewhere.
vincentm
05-02-11, 01:27 PM
Recheck all your connections and sensors.
maeng9981
05-04-11, 10:42 AM
Are you using your hand to tighten down the battery bolt? That's what happened to me when I hand tight mine and although it looked like it was secure, it didn't get the "full" connection. They need a real good connection.
alake
05-06-11, 02:55 PM
You all were right, I ended needing a new battery. Totally different issue than what I was dealing with in the first place.
Took her over to the "stealership" and they are saying I have a lower end rod/ bearing going bad. It's knocking against the crank. They want $2500 to tear into it, and they're not even sure that's what they'll find. I'm skeptic. I bringing her back home. Need a 2nd opionion.
When driving to the dealer, it acutally sounded better as I got around 50-55. Kinda wierd.
hcaddy95
05-07-11, 10:01 PM
I would take the serpentine belt off the motor and start it up and see if the knock is still there
alake
05-09-11, 02:37 AM
I can do that. What would that indicate if it does?
maeng9981
05-09-11, 04:52 AM
You can rule out the accessories (A/C, alternator, tensioner, etc) from the source of the knock.
Ranger
05-09-11, 11:41 AM
No need to remove the belt. Just release the tension enough to allow the belt to slip.
