: Drag radials on! RESULTS
6speeder
04-16-11, 06:01 PM
My best run was an 11.884 @ 116.16, with a 1.75 60', and with a DA of 7,000 feet. I launched from idle, DR's at 20 psi. Happy happy joy joy.
As the day got hotter and the DA went up, I tried different launch techniques. With a 1,500 rpm stall at 20 psi I spun and my 60' went to 1.88 and I spun on the launch. So I slowed down to a 12.01 with a DA of 7200'.
I lowered my pressure to 18 psi, launched at 1500 rpm, no spin but only a 1.87 60' time. So I went even slower probably because the engine temp was up and the DA was now up to 7,500'.
Seems this car still likes an idle launch, then floor it for a best time.
BTW my previous best on stock tires was a 12.21 @ 119.8 with a 2.08 60' time at a DA of 6,600'.
One thing that cost me time on my two slower runs was the car hit the rev limiter, just for a split second, on the 3-4 shift. Does the tune on these cars shift just off rpm, or is it mph also as it is on some newer corvettes?
newcadman
04-16-11, 06:25 PM
Congratulations. Well done. Rest assured your best run is yet to come. With some engine cooling between runs and not hitting the rev limiter on the 3-4 shift you are definitely going lower.
From what I've been told the hitting of the rev limiter (on the 3-4 shift) can be eliminated in one of two ways. The rev limit on the 3-4 shift can be raised from the stock 6200 rpm to say 6400 with a tune or according to forum member "snzuloz" if the shifter is moved from "sport mode" to "regular mode" before the tranny shifts from 3 to 4 then he reports it doesn't hit the rev limiter. After it shifts from 3 to 4 he says he moves the shifter back to sport mode and goes through the traps with it in sport mode.
Hope that helps.
JOEYCTS-V
04-16-11, 07:09 PM
Interesting. I will have to try that if I don't have a tune the next time I go the track. My car did the same thing. Congrats on the timeslip.
Cowan480
04-16-11, 10:34 PM
Nice!!
I just went to MThompson DRs and knocked off .4 off my quarter mile!! Good stuff!
newcadman
04-16-11, 11:14 PM
Nice!!
Could you compare your actual before and after ET's and 60' times since going to the Mickey DRs ?
gnxs
04-17-11, 08:35 AM
Congrats man, I always feel for you guys running those types of DAs.
As for hitting the limiter on the 3-4 shift....yes it's happened to several of us. I've yet to have that issue rectified in my current tune which is why I haven't raced this year yet. It has been MOST frustrating. I believe one or two guys have rectified it, perhaps they'll chime in on what they changed.
6speeder
04-17-11, 08:56 AM
Thanks guys. That's interesting that I'm not the only one hitting the rev limiter on the 3-4 shift. I'm running Jess's tune, I'm gonna ask him.
newcadman
04-17-11, 10:12 AM
Would be good to hear what Jesse has to say about the issue. Could you update us after speaking with him? Thanks
