: Drag radials on!
6speeder
04-15-11, 12:35 PM
Well, I was tired of spinning all the way through second gear so I bought a pair of drag radials and Corvette wheels. The tires are BFG DR's, 295/35-18 which are a little wider and a little shorter than the stock tires. The wheels are Corvette C5 thin spoke reproductions, in 18-9.5" size. They fit perfectly, don't hit on anything, no spacers or grinding needed, but the spokes are close to the brake calipers. They are about 2 pounds lighter than the stock wheel/tire combo. I'll have pics and report gains from the drag strip tomorrow.
My previous best was a 12.21 @ 119.8, with a 2.08 60' when the DA was 6,600 feet. That's right, six THOUSAND, six HUNDRED feet.:crying2:
It'll probably be higher tomorrow. :banghead:But, that's what I get for living in the high desert.
newcadman
04-15-11, 02:30 PM
What mods?
With any decent 60', it's an 11.xx !
Best of luck
gonfishin
04-15-11, 03:02 PM
Good luck and break that 12 second barrier :burn:
gnxs
04-15-11, 03:09 PM
Considering the elevation, you're already hauling the mail. Easy 11 second timeslip in your future. Make sure you do at least one launch from a dead idle, I think you'll find you'll be rewarded in your 60 ft.
6speeder
04-15-11, 04:02 PM
Thanks all. So far I've found a dead idle launch to give the best times, but we'll see with the DR's. My mods are a W4Me upper pulley, his handheld canned tune, and a K&N with the airbox mod. It made 534 rwhp SAE, but uncorrected because of the altitude that's really only 444 rwhp.
Yes, I really want an 11.xx, "times" will tell.:bonkers:
shade
04-15-11, 04:18 PM
Damn where do you live Mt Everest?
newcadman
04-15-11, 04:41 PM
FWIW, you may wish to start with about 20 psi in the DR's and don't be hesitant to drop the psi down to 17-18 if need be. With a GOOD HEALTHY burnout and some engine cooling the 11's are yours!
6speeder
04-15-11, 05:14 PM
HEH. Sometimes it seems that way. Albuquerque Dragway is at 5,400 feet, Drag times has it listed wrong BTW. But... our spring/summer DA is usually in the 7,000 feet range.
NEWCADMAN: We think alike, they're at 20 right now. :cool2:
