: DIY post for changing rotors 2005 cts-v
Goonie
04-06-11, 09:52 AM
Hey guys, I've been looking for a DIY post on changing rotors on a 2005 cts-v.
Pads are simple, just not sure if I have to take the whole caliper apart or just the bracket.
Any help is appreciated!
Thank you.
UnsafeAtAnySpd
04-06-11, 10:07 AM
Remove wheel, unbolt two caliper bolts, unscrew rotor retaining bolt, remove rotor, reverse procedure, rinse, repeat.
darkman
04-06-11, 10:11 AM
Rotor removal is simple. Once the wheel is off, you remove two caliper bolts and take off the caliper. The rotor is held on by a single torx screw. Reinstall the calipers using threadlocker and 88 foot pounds of torque. You may need to "re-spread" the pads if they close up on you, but that can be done with a C-clamp or similar device.
Goonie
04-06-11, 10:54 AM
Thanks guys, I figured as much. I know the rotor change is totally different on an 04.
Anyone know what size bolt the bracket is?
DrSpeed
04-06-11, 12:48 PM
http://www.cadillacfaq.com/faq/index.html
click on brakes.
It does not cover rotor removal, but it's only one torx fastener.
UnsafeAtAnySpd
04-06-11, 12:54 PM
Wait what? How is it totally different?
I think it's 19 mm. But that's just from memory.
tweeter81
04-06-11, 12:55 PM
I changed my rotors and pads last year, and I remember that if you need to spread the pads out further, just use your hands, it is really easy. You don't need any special tools for it.
tweeter81
04-06-11, 12:56 PM
The brakes are identical between model years as far as I know, so the procedure is not any different.
thebigjimsho
04-06-11, 01:36 PM
Yep!
