: Fleetwood Lift
04-02-11, 09:31 PM
What's the best and easiest way to lift just the rear of a 95 Fleetwood about 2 1/2 to 3 inches?? I'm installing 265/35/22's and don't want the back to rub. Compressor stills works, but I don't want to rely just on that.
AirLift 1000
Coil Spring Spacers
or Other ways
Any guidance would be appriciated.
04-02-11, 09:38 PM
The shocks aren't made to hold up the car anyway and can damage the car if that's relied on. Get different springs.
04-02-11, 10:08 PM
Spacers under the springs. Whatcha running up front?
04-02-11, 10:34 PM
I'm running the same size up front. What kind of coil springs can get and from where?? Will I have to use strut extenders???
04-02-11, 10:49 PM
I dont think you'll have to change anything, you just wont have the suspension travel you have now. I've been using my shocks to support the back of my car, no damage yet but I would like to know how it would damage the car. I had a one inch spacer on another caddy and they worked nicely.
04-02-11, 11:21 PM
Why not just run the right size tire and leave it at stock height? Tucked 22s look good...
04-02-11, 11:27 PM
So that's a 1 inch spacer on top of the existing coil sping. And you didn't need to adjust any other part of the suspension???
04-02-11, 11:34 PM
The rear of my caddy was sagging because of the sound system. The shop put in Stock height cargo springs and a 1" spacer and left the stock shocks. It raised the back end about an inch but nothing else was done. I would think you could get one and a half inch spacer with no problems, maybe a 2".
04-03-11, 01:20 AM
I fell ya Jay, I just don't want to be on the highway and a shock goes out. Now I'm stuck on the side of the highway looking crazy, lol.
04-03-11, 01:25 AM
I really think I would have to use a strut extender if I use 3" coil spacers. Aye csbuckn, after you installed the coil spacers did it ride like a Cadillac or did it feel like military truck????
04-03-11, 02:10 AM
It felt like a cargo van. The recoil was viscous. If I went over a big dip, the subs would catch air. The cargo springs were a little much so you could use your stock springs with some decent shocks.
04-03-11, 03:31 AM
Can I just use the factory shocks and springs, then add the spacer to the coil spring.
04-03-11, 09:53 AM
If you add a 3" spacer, I think you'll have to change the shocks but you can use the springs. 3" in the back only?
04-03-11, 12:22 PM
that size tire on a 22" rim wont rub. you can lower the car 2" and it still wont rub, so no need to lift it
04-03-11, 02:54 PM
Would the car look too jacked up in the back with 3" spacers??? How will it look??? Anyone have any pictures????
04-03-11, 09:19 PM
It will look like it is on The Dukes of Hazzard. In other words, ridiculous. It's your car, though... do what makes you happy.
Do you have the tires mounted up on the wheels already? If yes, put them on and see what they look like without jacking it up.
Angry Matt
04-03-11, 10:34 PM
I don't think '22's are big enough to need the lift. I've seen many '20's on those cars with plenty of room for more wheel. Imo, if you're going to lift it, tru's, vouges and chrome buckles are the way to go...
04-03-11, 11:03 PM
I don't condone lifting any Cadillac, but if you're gonna do it, I wouldn't use the shocks to do it. You're going to be putting stresses on the shock mounts that they weren't designed for.
04-03-11, 11:21 PM
I have some 3" coil spring spacers, but I'm going to send them back for some 1 1/2" so I won't have to use strut extensions. I definitely don't want the Bo and Luke look, lol. Thanks for the info everyone. The wheels (22" 5-stars)should be here in about a week ready to install. I'll post pictures, yall know I post pictures of everything, lol.
04-03-11, 11:31 PM
What size tires? Just look on youtube for caddys with 22s and see what look you like.
04-04-11, 09:54 PM
The tires are Yokohama 265/35/22, the ratings were pretty dam good for ride comfort and road noise.
04-05-11, 01:21 AM
as i said before you can lower your car with that tire size and it wont rub so factory height you wont have any problems
04-05-11, 11:07 PM
Thanks for the advise everyone. This is another good thread for the next man to use.
