: dome lamp replacement?
JackG
04-01-11, 01:13 AM
I searched the manual but couldent find anything on this..
Do you know how to replace the dome lamp? Do you pop open the cover? I dont want to damage it at all.
Also, I wanted to replace with this. Does anyone know if it will fit offhand?
http://cgi.ebay.com/ebaymotors/1-25-1-72-Interior-Dome-LED-Panel-Light-Bulbs-6-SMD_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dLVIQ26ituQ3 dUCIQ26otnQ3d3Q26poQ3dLVIQ26psQ3d63Q26clkidQ3d8140 071886370897108QQ_trksidZp3286Q2em7QQcategoryZ3371 3QQitemZ160478371637
sub613
04-01-11, 12:11 PM
You've GOT to tell us what "Year" and what "Model" Cadillac you have !:hmm::hmm:
It It's a 2005 or Later, I believe it's is Wedge type bulb,
It's been a WHILE, since I pulled it down, BUT carefully Pull down on the
outer Plastic housing and Remember it may be on wires.
I put High power LED's and they "Are" Bright ! which is what I wanted !
194 equivalent.NOT 212 or 211.
Good Luck !
OOPS, i notice you have an STS,in that case, the above info,
may apply to your car.
JackG
04-02-11, 12:36 AM
2005 sts v6
Anyone know for sure?
chazglenn3
04-05-11, 09:05 PM
Yes, I know for sure. The overhead console is held in place by four clips. Pull gently from each corner until the clip releases. I recently replaced my console because the lights in the sunroof switches were burned out.
JackG
04-06-11, 07:29 PM
Ok, I will try. thanks a lot.
