: 4.1L Heater Issue
03-31-11, 01:25 AM
After getting my car back from the mechanic in November (after nearly three weeks), I noticed that my usually trusty heat was no longer... trusty. Sometimes it worked, sometimes it didn't; in other words, several mornings I got a refreshing blast of cold air when it should have been hot. And now I've noticed that whenever I turn on either one of my defrosters, the 'No Charge' light pops on. Any ideas?
03-31-11, 03:41 AM
What was it at the mechanics for? Check your charging, check all fuses, and check vacuum lines, underhood and under dash. You may have an electrical problem, and it may or may not be related to what's going on. You could have a bad thermostat, but maybe it's just a mix door that's disconnected. Depending on what it was in for, check in the vicinity of that in particular.
03-31-11, 10:17 AM
I had it in the shop because of a bad ISC motor that caused the car to stall out on me. So pretty much everything that's around that, then?
