: 275/35-19 Front Tires
BluMachine
03-25-11, 12:53 AM
Has anyone had 275/35-19 mounted on stock rims on the front of their car?
Anyone know if it will work on a stock ride height car with no rub?
ChasJr
03-25-11, 01:47 AM
I have 285 on mine with no rubbing..
BluMachine
03-25-11, 09:52 AM
Thanks for the reply.
Is this on the stock rims?
What size and brand?
BeagleBrains
03-25-11, 11:12 AM
This would surely reak havoc with Traction Control.
Tire Size Calculator http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp
Calculator based mathematical equations of the sizes entered,
Compare: 255 /40 R-19 TO: 275/35 R-19
Front to Rear Diameter comparison: 25.5 TO 26.85 = +1.35
Front to Rear Circumference Delta: 80.1 TO 84.37 = +4.27
BluMachine
03-25-11, 01:01 PM
Looking to pair these with shorter rear tires. Probably 305/30-19.
You should calc the percent difference in diameter front to rear stock vs new and compare the change in stagger ratios.
Stock front: 27.0
Stock rear: 26.8
Front to rear:1.0075
275/35-19 front: 26.6
305/30-19 rear: 26.2
Front to rear:1.015
Change in stagger ratio: 1.015/1.0075 = 1.0075 or 0.75% increase in stagger ratio from stock.
1% change will not throw off traction control.
I've been running MT ET drag radials all winter rear 305/35-18 = 26.4 with stock size fronts (1.5% increase in stagger ratio) and no issues with traction control.
baabootoo
03-26-11, 12:25 AM
Tire Rack shows a little difference. Stock F/R, there's only a .1" difference in diameter (27"/26.9"), which would grow to a .3" difference (26.6"/26.9). I'd say this is well within normal ranges. After reading Chas' thread, I'm still torn on what size for the fronts this summer. I wouldn't mind a tad taller tire, and width, to fill out the wheel well, and add a little grip for the road courses.
