: Is my Gauge wrong???
magna-v
03-21-11, 04:28 AM
I have a 2004 v maggied w/magnaflow x-pipe and catback, i bought a plx DM-100 gauge from a buddy of mine with the boost and afr sensor modules. this setup was on his Grand National and worked just fine and read accurate boost #'s as well as afr.
I installed everything tonight except for the wideband because i dont have any extra o2 bungs at the moment but i did a couple WOT runs on the freeway and im not sure if i connected to the right line on the maggie. at 5800 rpm WOT it read 9.6#'s of boost!!! seems high to me. Im maybe a couple hundred feet above sea level in seattle on the freeway but dam!! as far as i know it has a recent maggie due to the carbon shaft and 2.8 pulley and exhaust. i bought the car with the mods and not much background info because it was from a dealer. the only thing i got was a box of stock parts in the trunk.
The line i tee'd into was the line that goes into the magnavolt about 6 inches away from the maggie itself. the gauge was very accurate on my buddys GN so im not really not sure what to think, Help me out here:crying2:
CancerJCC
03-21-11, 12:46 PM
Is there an electronic sender or does the vacuum line run all the way to the gauge?
magna-v
03-21-11, 03:57 PM
its an electric sender
Twitch
03-21-11, 07:33 PM
Could be a ground offset problem. Easy to check the calibration though. Key on, engine off it should read zero.
magna-v
03-21-11, 08:40 PM
twitch, just checked like you said, it does read zero but .2 flashes flashes once in a while but for the most part it stays at zero
CancerJCC
03-21-11, 09:07 PM
The reason I ask is what Tony said. Grounding offset problems. Do you have anyway to change the gauge settings? Like a program that came with the gauge? If not all you can do is ensure a really good ground and roll with the reading it gives you. I personally installed a 2 bar MAP sensor so I could see what boost I was getting in HP Tuners over a WOT run.
Heres some light reading on grounding offsets: http://www.innovatemotorsports.com/forums/showthread.php?t=3410 They are terrible in the V btw...
CancerJCC
03-21-11, 09:12 PM
BTW Here is a thread that can give you some comparison as to what boost level you might be seeing. Remember boost is just a measure of restriction so there isn't an exact number but some of the guys will be close to yours.
http://www.ls1gto.com/forums/showthread.php?t=142006
One guy with just more cubes for example:
I'll just add a couple.
Stock LS2 engine with just catback magnaflow, stock 2.8 blower pulley= 6.5 psi.
Stock LS2 engine with Magnaflow catback, Kooks 1 3/4 LTs w/catted midpipes, 2.7 pulley=6psi.
ctsv154
03-21-11, 10:40 PM
Look at the harmonic balancer and see if it's stock. If it's a huge silver Innovators West, that would explain the extra boost. If it's a stock black one, somethings up.
Twitch
03-22-11, 09:24 AM
Also, if your sure you have a 2.8 in front check the rear pulleys. Is one smaller?
CancerJCC
03-22-11, 03:11 PM
Good points. BTW If its huge and silver like Bobby suggested then you need to get it off there asap and I'll trade you for the black one you need. :)
