: Hard Start
03-19-11, 02:52 PM
2005 STS V*8, Hard Start issues, also will not start with remote, smell of gas when it does start, OBD codes P0300 and P0442
03-19-11, 03:24 PM
The remote start won't work until the codes are cleared. It could be lots of things so I'll let a member with more experience with the codes make suggestions. (I still have more than 6 months of CPO remaining, so I'd just make am appointment with the dealer.)
Good Luck!
03-19-11, 05:53 PM
The P0300 is engine misfire and the P0442 is Evaporative Emission Control System Leak detected. I don't know what the cause is.
03-19-11, 10:31 PM
Emission Control System Leaks can just be a loose gas cap. A misfire code doesn't tell us much.
Is the hard start issue in all conditions? Hot, warm cold, wet or dry? Any pattern at all?
03-21-11, 12:55 AM
Could be a bad coil or fouled plug this can cause excessive unburned fuel resulting in the fuel smell. Since each plug has its own coil probably need to get diaganostic done.
03-21-11, 08:49 PM
Does it have the original plugs? How many miles?
If replacing plugs, use only OEM.
