: Horn Location?
_ike_
03-14-11, 10:07 PM
Do any of you know where the horns are?
I want to put the four note horn in, the four notes are still available from GM ( A,C,D,F). I think this would be easier than doing the trumpet horn option but I might do it in addition.
I was told that the DTS already has two of the notes, they should be marked on the horn housing IIRC. I can't find them to see what they are. I can't see them under the hood and it is raining so I haven't crawled under the car yet to look.
Thanks
HartfordGuy
03-15-11, 06:57 AM
I had thought the same thing. The Caddy horns of the 70s and 80s sounded so much better. Much more commanding.
_ike_
03-16-11, 01:43 AM
From what I've been able to find online the DTS has the A and F note horns. I need to find where they are and if where I can mount the C and D horns and I'll need to build a harness to power them.
TURBO2
05-29-11, 08:35 PM
Thanks
The horns should be underneath the plastic shield on the drivers side. Get under the car, take the shield off and you should see the two horns.
