: Front Sway-Bar Diameter 2005 CTS-V
6 SPEED Z
03-07-11, 02:01 PM
What is it??
CI-V-IL
03-07-11, 02:54 PM
I believe its 26.6mm...
AAIIIC
03-07-11, 05:48 PM
Not even close. It's 26.5mm!!
6 SPEED Z
03-08-11, 12:51 PM
So if I tried a 26mm universal poly you think it would be too small, or a 27 would be too big?? Looking for something to replace the worn stockers.
CI-V-IL
03-08-11, 01:24 PM
Are there any inch sizes that could get you closer? I would go a tad small before I would go a tad big.
AAIIIC
03-08-11, 02:34 PM
I'm using 26mm ones. As CI-V-IL said, going a little too small is better. If I was really concerned about how tight they were I could just sand the inner bore a bit to open it up. If 27mm is too loose, though, there's really nothing you can do to fix that.
6 SPEED Z
03-08-11, 10:02 PM
True, easier to take away then add, which poly mount are you using? I was thinking of something fron Energy Suspension in a universal mount and make it fit the V mount.
CI-V-IL
03-09-11, 08:35 AM
http://www.energysuspensionparts.com/Universal-Sway-Bar-Bushings.asp
...just need to take a few measurements and find the bushing that matches.
6 SPEED Z
03-09-11, 08:41 AM
That is exactly what I was looking at, thx. Any tips on end links? I was going to use Rock Auto for a Moog set, any other advice??
AAIIIC
03-09-11, 05:44 PM
I can't remember if the ones I have are Energy or Prothane. Shouldn't matter much. I broached this subject before - I think if you search this forum or the Performance Mods forum for "universal" you'll find the details.
