: Battery Tender Plus Install
CTBB
03-07-11, 01:36 PM
OK, Did a search and though this subject (under float charger) came up, I have a slightly different wrinkle, and I'm looking for help. I replaced the battery in my '05 under a year ago with a quality piece from Auto Zone. As I use the car primarily for long distance travel, preferring to drive more economical transport around town, I've found it necessary to recharge the battery 2X now, after not driving her for 10 days or more. I purchased a quality tender and wish to use the leads with a ring terminal on the ends to permanently wire it up to the battery, to avoid having to remove the engine shield every time I plug it in, and hanging alligator clips on the side terminals seems rather flaky. Herein lies my problem.
The factory battery leads with plastic covers make it impossible to attach the ring terminals under the connection. I fabbed up some right-angle bars of flattened 1/2" copper tubing, drilled appropriate sized holes and was hoping to slip them onto the battery terminal bolts, leaving a tab at the top pointing forward, allowing me to nut & bolt the ring terminals securely under the engine shield. This short tender cord (approx 24") ends in a weather-proof rubber flat plug with rubber cover that I would leave exposed near the hood strut for easy access. To my dismay I find the bolts on the battery leads are so short they will not accommodate the thickness (approx 1/8") of the copper bars. To further complicate finding a hardware solution, these bolts are "captive" on the battery leads, preventing any substitution of slightly longer bolts. :banghead:
Has anyone else encountered this, and if so, what was your solution? Am I stuck using alligator clip connection and removing the dust shield every time?
Apologies for the long explanation. :bonkers:
Glenn
CTBB
03-09-11, 10:50 PM
Gee folks, 102 views and no suggestions, or experience with this. I thought we had some Cadillac techs on here that might be able to help. :helpless:
Glenn
rzambrano
03-10-11, 02:57 AM
Its not a typical topic. Your turning your Caddy into and electric vehicle sort to speak by having to "plug it in". If you are worried about the battery losing its charges over long periods of downtime, simply disconnect it.
chazglenn3
03-10-11, 09:53 AM
Yeah...I have never installed a battery tender on anything other than my motorcycles.
CTBB
03-10-11, 02:24 PM
Not sure where you get the "electric vehicle" reference, but disconnecting & reconnecting the battery involves getting under the engine cover and wrenching, versus my desire for a simple plug/unplug process when I wish to store/drive the car. Obviously not a huge deal but inconvenient. I'm also just stubborn enough to want to overcome the obstacle presented by the designers. :annoyed:
Same issue :How does one wire up a trailer hitch, which I also plan to do? Or an external amp, just to name a few? Thanks for your response.
Glenn
rzambrano
03-10-11, 03:26 PM
I got the electric vehicle things as sort of a metaphor, by having to charge it at home. Nevertheless, I do not have any other suggestions.
EChas3
03-10-11, 08:54 PM
Charge it through a cigarette lighter power outlet.
CTBB
03-10-11, 11:43 PM
Really? I've seen AAA use a cigarette lighter plug device to keep memory, etc powered when replacing a battery, but never seen one to float-charge. I'll take a look for one. Thanks!
Glenn
Well, I'll be ....! Right there on Amazon, page 2 !! Thanks again EChas3.
EChas3
03-11-11, 09:04 PM
No warranty expressed or implied :)
The STS lighter/power outlets are not 'switched' and I don't think they are in the Inadvertent Power Battery Saver circuit. I think it would work.
CTBB
03-11-11, 09:07 PM
I should know soon. Just ordered one, and a 12.5 ft extension cord. Here's hopin'.
Glenn
