: AC compressor belt
MO POWA!
03-07-11, 12:40 PM
A couple of weeks ago i noticed my AC wasn't working (hadn't turned it on since last summer). It turns out that the AC compressor belt had came off, simple enough i just put it back on there since it was not damaged. I also checked the pulley and it was straight and properly aligned. Well it worked for a couple of days and then it came off again! :hmm: Any ideas what could be going on, ill probably go buy a new belt and see how that works. I need to fix it before the Houston summer rolls in.
trhs75
03-07-11, 10:06 PM
I'm not as knowledgeable as most of the people on this forum, but is there a chance that the old belt (or even if it's a new one!) stretched and you need to adjust the tension?
Den_93
03-07-11, 10:30 PM
Make sure the Harmonic balancer isn't working it's way out. My AC belt came off and noticed the balancer was off by 1/2 inch.
ctsv154
03-08-11, 12:11 AM
What Den said! Thats the first thing to go is the a/c belt when that balancer starts walking off. I had it happen 3 freakin times!!!!
