: 4.9 Individual Throttle Body project
Ghost C
03-04-11, 10:14 PM
This
http://www.collectorcarsforsale.com/parts/parts-images-large/1990-cadillac-allante-intake-manifold_120676804372.jpg
Plus these
http://img.photobucket.com/albums/v300/ghostc/IMG088.jpg
And runners that I'll need to fabricate. I decided to scrap the 4 tb into 2 project and try and set up ITB's on the 4.9. The CBR600RR throttles are 40mm each, which should flow plenty to feed a 300ci engine that only revs to 5,000rpm. The manifold won't be here until Wednesday :(
Issues that I'll need to work out:
Vacuum log for brakes, FPR and MAP sensor, other stuff would be fine to run off one runner but the FPR, MAP and brakes will need a vacuum log
Filter setup
Fuel rail - My manifold isn't coming with the fuel rails from the Allante, however I think the standard 4.9 rail will work? Someone correct me if I'm wrong so I can start looking for one
EGR - Either will have to be removed, or adapted to work with this manifold somehow. Ideas on this will be appreciated.
drewsdeville
03-04-11, 11:00 PM
First of all, I wouldn't expect much gain. The stock throttle body is more than enough to feed the 4.9's small cam and valves. THOSE are what really dictates how an engine breathes. Even with the largest throttle body you could possibly adapt, the engine can only flow as much as the cam and valves allow.
Would it be a problem that the fuel injection is speed density rather than mass air flow? In theory, a larger, better flowing throttle body will reduce vacuum. That's bad because the PCM's MAP sensor tables are matched to the stock throttle body: for any MAP sensor reading, the PCM knows how much air should be passing the stock throttle body. If you change it, the PCM doesn't know that and still adjusts injector pulse width as if the stock throttle body was still in place. Without a PCM tune, I would expect that you will find a large drop in throttle response and overall worse performance.
Ghost C
03-04-11, 11:17 PM
It's not the size of the throttle bodies. One throttle body feeding one runner into one cylinder gives better throttle response and makes more power by being more efficient than a throttle body feeding a plenum feeding runners. It also minimalizes differences in air flow between each cylinder.
I don't think you understand what a MAP sensor does. It has nothing to do with the throttle body and they are not tuned to each individual application. The 1 bar MAP sensor is a common part used on a ton of cars and each PCM is calculated to the engine's specs. MAF would not work any better than MAP. The ideal solution is something called alpha-N tuning, but that's another story for another stage of engine tuning. The problem is, I will need to make a vacuum log for the MAP sensor, and the fuel pressure regulator, and the brake booster. The only issue is figuring out the perfect size to use for this application.
I forgot to put in my "issues" list that I also need to calculate optimum runner length and diameter for the setup to produce usable power for the 4.9, I think the runners will have to be close to obnoxiously long for a low revving engine.
drewsdeville
03-04-11, 11:25 PM
Er...that's exactly what I was trying to get at. I never claimed that the MAP sensor was tuned per application. Rather, how the PCM interprets data is different per engine (not all engines flow the same volume of air at a given BAR). If the throttle bores are larger than stock, which in turn reduces vacuum at the throttle body (where the MAP is connected), the PCM WILL need to be tuned for this to work correctly; the stock fueling tables will no longer be correct. Else, the PCM will assume a larger load than actually exists (due to reduced vacuum), unnecessarily enrichining the mixture.
Example: At X BAR the PCM assumes that Z cfm flows past stock the throttle blades, and fuels accordingly. Now, you change the throttle body to something with larger bores. X BAR now occurs at a different load/rpm than stock, and Z cfm now occurs at some other BAR. However, the PCM continues to fuel for the predetermined cfm's per BAR for the stock setup.
A MAF would be more ideal as air measurement occurs AHEAD of the throttle body, and cfm is measured directly rather than assumed through manifold pressure, so any changes made would be, in effect, detected by the PCM.
Ghost C
03-04-11, 11:35 PM
The throttle bores being larger than stock has no effect on how much air the engine draws in at idle. The only effect of individual throttle bodies on a MAP sensor is the difference in pulse makes it screwy if you do not use a vacuum log, which is why I'm going to use a vacuum log.
MAF is less than ideal because I would have to build a plenum on top of the throttle bodies and then pipe air in through a tiny MAF-sized hole, mostly defeating the purpose of an individual runner setup which is immediate throttle response. I'd also have to switch to stand alone engine management, and at that point (and price tag) I would just use alpha-N tuning with stand alone because it is based on rpm, temperature and TPS position - ideal for individual throttle bodies, and it would be easier to tune than a MAF conversion. Which is something I intend to go with... Eventually.
I know it causes you physical pain any time someone mentions "performance" and "4.9" in the same post, though, so I'll tell you something that you'll like to hear... I've spent less than $220 on this setup so far.
drewsdeville
03-04-11, 11:48 PM
Correct, the heads, cam and intake determine that. But what does it do for VACUUM?!?!? Vacuum and air flow are NOT proportional. It sounds like you are assuming that.
Vacuum is generated by creating a restriction to the air flow. The throttle body is that restriction. As you mentioned, the air flow doesn't change, the engine draws in the same cfm's regardless of throttle body. However, if you change the amount of restriction by increasing or decreasing bore size, you change the amount of vacuum present. Smaller bores will raise vacuum, larger bores will decrease vacuum, air flow will remain the same. This change becomes apparent to ALL vacuum operated devices, including the MAP.
Ghost C
03-05-11, 12:02 AM
I fail to see how the throttle bodies have any effect on how much air the engine draws or atmospheric pressure. Do you think the PCM needs tuning mid-trip if you drive from New Orleans to Boulder CO? The difference in atmospheric pressure between the two cities would have a far larger effect than switching throttle bodies.
Vacuum is the difference between the absolute pressures of the intake manifold and atmosphere. Vacuum is a "gauge" pressure, since gauges by nature measure a pressure difference, not an absolute pressure. The engine fundamentally responds to air mass, not vacuum, and absolute pressure is necessary to calculate mass. The mass of air entering the engine is directly proportional to the air density, which is proportional to the absolute pressure, and inversely proportional to the absolute temperature.
And so on and so forth.
Look, you asked for thoughts and I'm giving you them. The fact that this is a 4.9 has nothing to do with my response. It would have been the same for a Chev 350 or a Geo 3 cylinder. Take it or leave it, but don't put down those giving you what you asked for.
I asked for input on certain areas of the fabrication, not someone telling me it won't work or that it's not worth it to try, which is generally your S.O.P. especially in this particular sub-forum. If you would have chimed in with a tip on how to use the EGR, a calculation for ideal runner length, or knowledge of the differences (if any) between the Allante and 4.9 fuel rails, I would appreciate it. However, you just want to say it can't/shouldn't be done, even going so far as to present incorrect facts in your argument against the project. I don't mean to be a prick, but every topic about performance in this forum has at least one post from you saying something negative, and it gets old.
drewsdeville
03-05-11, 12:11 AM
I never said it couldn't nor shouldn't be done, I merely pointed out what I think to be a potential obstacle, bud. All I suggested is that a PCM tune may be needed, nothing more.
If you want my advice on the intake manifold, I'd say build your own to accommodate either fuel rail and scrap the Allante intake. The individual throttle bodies would be great if all runners were straight, clean, and most importantly, equal length. Take a look at the picture you posted above...those runners are anything but that, much of it's design influenced by packaging restrictions under a shallow hood. Anything that you slap on top of that manifold will not change the performance characteristics that your manifold has. You really need to start from scratch and build a custom manifold from the heads to the throttle bodies to get some results.
Something like this would really take advantage of the idea. Notice all runners are identical in shape and length, running straight into the heads that this manner:
http://www.lakeheaders.com/sitebuilder/images/4_392_intake_hemi_4_-600x450.jpg
The problem with fabricating your own is that you have to accommodate for the goofy physical geometry on the top end: the narrow heads, pushrods passing through the intake manifold, valve covers overlapping it all, and accessories that are mounted to the intake, like the power steering pump and alternator. Again, IT COULD BE DONE.
the recluse
03-05-11, 04:13 PM
:food-snacking:
FWIW, the runners on the Allante manifold are real close to equal length, and I'm 90% sure the fuel rails are interchangeable.
IMHO, I would look into the throttle bodies combined flow rate as opposed to stock single TB flow rate. If close, I would look into stock runner lengths and diameters for the upper half of the manifold. If not close (I think 40mm throttle bodies are gong to flow A LOT more air), then I would suggest closing the diameters of the fabricated runners a bit to pick up the velocity of the incoming air. Tuned ports.
Too much flow is/can be a bad thing, especially if the air isn't rushing fast enough. On these short stroked motors you need more velocity than volume.
My .02...
quins90lac
03-07-11, 01:03 AM
Hey ghost i want to see this when you get it done.
Ghost C
03-09-11, 12:53 PM
http://img.photobucket.com/albums/v300/ghostc/IMG00499.jpg
http://img.photobucket.com/albums/v300/ghostc/IMG00498.jpg
Suspiciously, the diameter of the runners is only 2mm smaller than the throttle bodies. Hm.
Time for calculations and procrastination.
ehall
03-09-11, 02:33 PM
look about halfway down http://forum.britishv8.org/read.php?6,13482,page=2 and there is some pics of motorcycle throttle bodies on a tube manifold
Ghost C
03-09-11, 02:45 PM
That's basically exactly what my setup will be, except it will work with the ridiculous head setup of the 4.9
And my runners will be long enough to make power on an engine that only revs to 5k
Sevillian273
03-09-11, 04:03 PM
:food-snacking:
the recluse
03-09-11, 09:18 PM
Wow, that's all?!? The combined flow rate should have that motor breathing REAL easy...
Question though, do you have access to a dyno for a before and after? Just curious for a more black and white approach. I'm looking to put a 4.9 in my Firebird and since I would have to possibly mock-up some exhaust manifolds/headers why not tackle something like this too if the HP gain is good...:lildevil:
Ghost C
03-09-11, 09:28 PM
No before dyno, but I'll get an after dyno more than likely. I also intend to - at some point - fabricate a set of 180 degree headers for my car. Which will be awesome... and ridiculously complicated.
If your main goal is power and you want a 4.9, you should look at turbocharging. I prefer naturally aspirated cars, and I'm only looking to make around 280-300hp when the motor is fully done. ITB's will probably only be worth 30-40hp on their own.
drewsdeville
03-10-11, 12:29 AM
:histeric:
I'm gonna guess your estimates are about 50-60hp too high :P
Be sure and fill us in with the results!
Ghost C
03-10-11, 12:32 AM
:histeric:
Your advice is unneeded, your opinion is unwanted. Please refrain from trolling my thread.
drewsdeville
03-10-11, 12:38 AM
:jawdrop:
:rofl:
Ghost C
03-10-11, 01:42 PM
:jawdrop:
:rofl:
http://www.wcroberts.org/Paige_History/Images/1915-01-02%20Cadillac.jpg
:yeah:
drewsdeville
03-10-11, 04:22 PM
http://beckyyamamoto.files.wordpress.com/2009/12/dawson-crying.jpg
But anyway, parts of that would be great for WI's legislature at the moment! :thumbsup:
Cristofo
03-11-11, 03:56 PM
Ive been reading some of these posts lately. Ive noticed that peoples reactions to some of the things you're doing having nothing to do with jealousy. I think your posts come off a certain way that people don't care for and when they respond to you, you take it as hate or jealousy and envy.
Ghost C
03-11-11, 04:06 PM
Did you have anything relevant to add, or did you just want to prove your keyboard is functioning?
Cristofo
03-11-11, 04:09 PM
Yea I wanted to ADD that you don't get it, but as far as your project do whatever makes you happy.
the recluse
03-11-11, 09:24 PM
If your main goal is power and you want a 4.9, you should look at turbocharging. I prefer naturally aspirated cars...
The real reason I like the idea of a 4.9 liter is the fact I just rebuilt the entire (front and rear) suspension on my V6 Firebird. So to not deal with the spring changes and possible geometry changes in the front end, I've opted for the 4.9. It weighs 360 lbs, the V6 350. It bolts right up to the 700 r4 (for the V6), and gives me significant torque improvement. All this and it gets 20+ mpg.
Yeah, and I agree, I prefer N/A cars also....:cool2:
cadillac_al
03-12-11, 08:26 AM
:yeah:
It sounds like Ghost has a good handle on leadership and naysayers. I'm not one to rain on anybody's parade; I'm more of a wait and see kind of guy. Sometimes the naysayers may spit out a valid point that may not have been considered yet, so their criticism may have some value in the end. Keep us posted on your progress; just don't get mad and leave us. Peace.
Ghost C
03-12-11, 12:08 PM
Sounds like a great project, if you're interested in the ITB setup you might want to start looking for good deals on the Allante intake setup. Even if the ITB's don't work as well as I think they will, the Allante setup is good for 20hp and 20ft/lbs, and they're getting more and more rare. I know there's an upper manifold and throttle body on ebay right now for $50, here's the link
http://cgi.ebay.com/ebaymotors/allante-intake-manifold-and-throttle-body-_W0QQcmdZViewItemQQhashZitem2561ecf666QQitemZ16055 6709478QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries#ht_500wt_1182
This pretty much sums it up. Even someone as technically gifted and ruggedly handsome as myself (lol) can miss things or not think of something, etc. That's why I posted this thread, so that if someone with knowledge I don't have (see first post) feels like contributing, they can. I do not, however, appreciate a negative nancy and I think it's been well known for years that I have no problem speaking my mind on a subject.
I need to get some pipes and figure out how I'm going to work them from the manifold to the throttles, should have a mockup piece done within the next week or so. I also bought a set of 19lb injectors, but I'm pretty sure I bought the wrong style (good job me right?), I'll have to see when they get here. I know they'll still work, but I believe they're the older type injectors and not the Type III's with 4 holes. Next item to be purchased will be an adjustable FPR... And an Accel super coil... And better plug wires... And plugs... And... It never ends.
Ghost C
03-16-11, 04:08 PM
My injectors got here today, they're the 4 hole type after all. But one of them has a cracked pintle cap... So that sucks. Contacted the seller, we'll see how that ends up working out.
Cristofo
03-27-11, 08:02 PM
Have you figured a way to mount the throttle bodies to the intake hole confirguration yet?
Ghost C
03-28-11, 02:58 PM
Since you asked, the plan is something like this
http://img.photobucket.com/albums/v300/ghostc/IMG127.jpg
But the runners won't be nearly that long, or tall. That's just a quick mockup job. I'm using 90 degree elbows cut in half, then reversed (as if you couldn't see that), I did this to get a general idea of if I'll need to add sections between the two cut elbows to put the 2 sets of TB's further away from each other in order to mount the throttle linkage piece that will open both sets simultaneously. I'm undecided on that part right now, been focusing mostly on parts for other people.
Cristofo
03-28-11, 03:09 PM
reminds me of the Ferrari Pinifarina stacks.
http://rides.webshots.com/photo/1281943972066014194EtmBUC
STS_Seville_Hunter
04-19-11, 08:19 PM
ITBs can make good power over stock, these people must of never heard of a Toyota 4AGE ot a Honda K-Series it ITBs.
Ghost C keep up the avant garde work if you can get this functional you have my money. I'm especially interested too since most people here seem to think GM makes every car perfect to their 100 maximum potential.
Sevillian273
04-19-11, 08:37 PM
^Well, it's maximum potential within a specific design budget for a product that must work satisfactorily over a broad range of circumstances and this product needs to be offered within a specific price range. I'd say they've done pretty well considering the requirements. Is there room for performance improvement? Hell yes. Maybe not as much room and with less accessibility as the SBC market but it's there. Anything is possible with enough time and money.
drewsdeville
04-19-11, 11:00 PM
Not quite. It's more that many here realize that all of the components that make up the SYSTEM (designed as Sevillian explains above) compliment each other 100%. The heads only flow so much volume. The intake compliments the heads as best it can given the restrictions, and the throttle body compliments the heads and intake best it can. You cannot expect a change to one single component to drastically change the characteristics. You will be terribly disappointed.
It's like trying to upgrade a Pentium 4-era PC with 512GB ram and a nice new HD6850, and expecting a super computer that'll run anything you can throw at it. Not gonna happen.
Sevillian273
04-20-11, 09:40 PM
Yeah, but can it run Crysis? :p
drewsdeville
04-20-11, 09:42 PM
lulz.
Man, remember back when Far Cry and FEAR were the big stress testers? Far Cry sucked as a game, but man did it look great for it's day (especially when you ran it on XP64 with the "special" 64-bit patch). I remember I was all proud when I was one of the only people I knew with a rig that could run that game well - an FIC AM37 mobo, Athlon XP 2600+, 768mb DDR, and a Gainward FX5600 Ultra!
Sevillian273
04-20-11, 09:51 PM
I didnt get into PC's untill 2009 so that's all Greek to me! Far Cry is what started it though. I had to see it in its full glory so I upgraded a craigslist Asus board with 2 gigs and the best an agp card I could find - a Sapphire HD3850. I thought I was hot shit with my 8000 3dMarks.
drewsdeville
04-20-11, 09:58 PM
Well, that's a testament I guess. My above story is from 2004, the year the game came out. 5 years later in your 2009 story, it still looked awesome.
Maybe I should start another PC thread in the lounge...
