View Full Version : water leaking from hole on back of engine!
Lewis Rolen
02-27-11, 06:15 PM
My 2001 catera was running fine,after I replaced the auxilery water pump,water started pouring out quicklly,I finally found out where. Bending over from the drivers side,stick your hand down touching the flat back of engine,I looked with a mirror and the water is pouring out a half inch hole,what go's in there? can't find anything about it..Thanks Kip
AHazzardToAll
02-27-11, 08:29 PM
Freeze plug? If so,....
http://cgi.ebay.com/ebaymotors/1-RUBBER-EXPANSION-PLUG-LOT-FREEZE-4-219-4003-_W0QQcmdZViewItemQQhashZitem563fd83241QQitemZ37043 8320705QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Just make sure to order the right size. ;)
96whitez28
02-27-11, 11:16 PM
The cylinder head has freeze plugs of it's own. Damn that sucks if you ahve to pull the head off!!
AHazzardToAll
02-28-11, 12:18 AM
You should be able to replace it without pulling the head, if it is the head. might be just enough room.
