View Full Version : 425 in a 93 fleetwood
02-25-11, 05:51 PM
I have a 93 fleetwood that runs ok...Im doing a frame off rebuild on it and doing some major changes to the body...ive been wanting to to do somethin different for an engine swap..thought about a 2000 chevy v8 fuel injected...but no i wanna put in a 472 or 500 but the 425 is whats most available at the wrecking yards...can any one tell me what problems i will run into in this swap? i know the 77-96 frames are the same
02-25-11, 11:20 PM
I would look to buy a donnor car.. A 77to 79 full size RWD car.. this will have just about all the parts you will need to go to a caddy motor...If I was going to go through all the trouble of doing a motor swap it would be a 472 or 500... A 94-96 crossmember will make dual exhaust eazy...You will need a th400 if you go with a big caddy motor... thats all stuff in a donnor car..
02-26-11, 10:47 AM
Im hoping to get a 472 or 500 thats what i want but whats more available is the 425 at my local pick n pull....Hopefully when im ready to pull the engine there is a 472 or 500 there but if not i will get the 425...i dont see any real problems with mounting it as the 77-79 frame is the same as a 93....i will however be getting the transmission with it....Anyone here know where i can get the rochester carb rebuilt?
02-26-11, 01:43 PM
You can do a mild 425 for less money than a mild 500, primarily because 425 motors can be had for a song. A good cam, worked over heads, rebuilt Q-Jet, dual exhaust, 500 manifolds, and a worked over 500 intake would do wonders for a 425.
At the extreme end, 425 is no match for 500. But for a driver, it makes a lot of sense - especially in your case, where you have easy access to a donor car. There is a significant cost/effort penalty over throwing in another Chebby, but the SBC can't match the BB Cads for smoothness.
These guys did my Q-Jet. Give them your specs and intentions, and they'll rebuild your carb to suit. Ballpark cost is $250.
02-26-11, 05:23 PM
Which engine is in your Fleetwood? I have that car with a 5.7 Chevy in it, which seem to haul it around very well. It has the trailer package, with a 3.73 rear end, so it like gas quite well.
