: 02 Deville rear map light parts
Fast
02-23-11, 05:12 PM
Well when I was changing the light bulb shit flew everywhere are the springs contacts and connectors available? The part that sandwitches together lost all of the plastic nubs also as they broke off.
RippyPartsDept
02-23-11, 05:26 PM
http://img830.imageshack.us/img830/9593/rearreadinglamp.jpg
you're talking about #11 - #16 right?
those parts are all sold separately ...
Fast
02-24-11, 12:31 AM
I am pretty sure it is #12 and #15
There is a spring a brass piece and two plastic gear pieces that acts like a pen when you push the button, These go between the two parts 12 and 15.
12 has the wire with the end that also broke, it fits together with another piece that has female holes.
So basically #12, #15, and the spring, plastic gears is what I am looking for.
where can I get a digital copy of the pictures you have posted with the breakdown of parts for the full car?
RippyPartsDept
02-24-11, 11:11 AM
OK, so #12 is the switch and #15 is the button... the button is color coded to your interior so your VIN would be the best thing to use to make sure we get the right color
the buttons range in price depending on the color, but you're in the $40 area (for both parts) at the discount
Fast
02-24-11, 01:52 PM
Do they come with the spring and little plastic gears? Im not worried about the button color because I just need the spring and plastic gear things if they come with them, do they come with them?
RippyPartsDept
02-24-11, 03:29 PM
I really don't know - you're seeing just about everything I'm seeing besides the full descriptions (which aren't much more than 'pushbutton' and 'switch') and the prices
i would guess that the switch has the spring part and the button just pops on to it (or maybe pops into the bezel) and just presses down on the switch
and to answer your question about the online catalogs there's a couple different places you can go
gmpartsgiant.com has a decent catalog but you have to sign up to get the full part numbers
compnine.com has a good catalog (and easy links for posting the pictures here) but often will not have any part numbers and i think 2008 is the newest year they have
another good online catalog is the acdelco parts catalog at http://parts-catalog.acdelco.com
there are other places too i'm sure but i tend to not use them since i've got the full gm catalog at my disposal
Fast
02-26-11, 11:18 PM
Thanks again! as luck would have it i found the pieces I needed.
RippyPartsDept
02-27-11, 12:43 PM
cool... glad you found them
Black Beauty DTS
07-03-12, 07:17 AM
Sorry to revive an old thread, but I am looking for the same parts as the OP which would be items #12 and #15. My car is a 2001 Cadillac Deville DTS and the interior color is black. Do you have these parts in stock?
RippyPartsDept
07-03-12, 09:07 AM
i don't show a button with black/ebony color to it ... can I get your VIN? that will sort out the color issue and make sure there aren't any other mistakes
Black Beauty DTS
07-03-12, 09:25 AM
My VIN is 1G6KF579X1U136576
RippyPartsDept
07-03-12, 10:42 AM
ok, so apparently the button has been discontinued in your color (#15)
the switch (#12) i can still get in just a day or two
#25641588
$43.29 - list price
$32.46 - forum discount
Black Beauty DTS
07-03-12, 06:00 PM
Thank you for checking. I'm not sure if the button has the spring mechanism attached to the back of it, because the diagram is showing #12 as the electrical switch that the spring mounts into.
If that is all that #12 has, then the button would have the spring mechanism. Also, I won't need a color matching button since I have that already. I'm currently missing the internal spring mechanism which I can remove from whatever button you can get.
Do you have any button in stock? If you do, that would be the only way to determine if the the spring comes with it.
RippyPartsDept
07-03-12, 07:33 PM
Ok if you send me a reminder on Thursday I'll check if the spring comes w the button. I think it does.
Black Beauty DTS
07-04-12, 02:43 AM
Will do. Thanks!
Black Beauty DTS
07-05-12, 02:42 AM
Can you check if there is a white plastic piece connected to the back of the button with a spring? Thank you.
RippyPartsDept
07-05-12, 11:44 AM
i'm having a hard time getting a picture of one
if you want i can get you the full list of dealers that have one of these buttons in stock and ask if they'll take a picture of it and send it to you
or you can get them to describe it over the phone \
(there's really not that many left after the ones i've already tried)
Black Beauty DTS
07-06-12, 06:15 AM
After looking at the diagram closely and checking my other map light, the spring mechanism is a part of the switch and not the button. Therefore, I'll be needing only #12. How do I go about ordering this part from you?
RippyPartsDept
07-06-12, 08:42 AM
Just give us a call.
we'll need your billing and shipping addresses (if different) and the credit card info to go along with it as well as a contact phone number
that's all
Black Beauty DTS
07-06-12, 11:37 PM
I'll call sometime next week to order this rear map light, and I'll ask for Chris.
RippyPartsDept
07-07-12, 09:29 AM
great
in case you forgot, check post #12 for the part number and price
Black Beauty DTS
07-11-12, 03:35 AM
I'll be calling you on Wednesday in the afternoon your time (in the morning my time), to order item #12 which is the rear map light switch.
RippyPartsDept
07-11-12, 08:26 AM
Cool... i've saved a price quote in the system for you to make your call go smoothly (also in case i'm out to lunch or not available when you call)
PQ2264
total w/ shipping: $57.46
if you don't get to talk to me just give my co-worker that price quote and you should be all set
we'll just need shipping/billing addresses and the cc info
cheers,
chris
Black Beauty DTS
07-11-12, 11:51 PM
PQ2264
cheers,
chris
Sorry Chris, I wasn't able to check this before I called you, but thank you for making this a smooth process.
Black Beauty DTS
07-20-12, 02:10 AM
Chris I received the map light switch today, and it works great after a cumbersome install. Since the other side switch is missing a spring, I will need to order another map light switch. I'll give you a call first thing in the morning your time (at around 7AM).
Black Beauty DTS
07-20-12, 07:34 AM
I called at about 7:20AM your time because the Rippy Cadillac website said that the parts dept. hours were Monday-Friday 7:00AM-6:00PM, but the lady who answered the phone said the parts dept. doesn't open till 8AM. Anyways, I'll need to order one Reading Lamp Switch part #25641588. I believe the switch is interchangeable for either left or right side, but I'll give you a call later in the day to place the order.
RippyPartsDept
07-20-12, 08:52 AM
our website has always had bad info of some sort ... i've told them about that many times but nothing seems to get done
those hours are for service ... we are open 8-5:30 and 8-2 on saturdays
and yes, the switch is interchangeable between sides ... talk to you soon
~chris
