: Please help - widest tire possible on Linea Corse 19x10???
sciroccokid
02-15-11, 08:44 PM
What is the widest tire I can run in the rear on a Linea Corse 19 x 10? I don't want to rub at all.
Thanks! I am going to order these tomorrow.
WesH8398
02-16-11, 03:20 AM
Without changing anything else, I've read that 275's are as wide as you wanna go in the back. Wider will likely hit trailing arms and/or rub fenders extreme circumstances. 245's for the front.
sciroccokid
07-14-11, 05:36 PM
Hey guys,
I am actually getting the new Linea Corse LC855's (same dimensions as the corse's mentioned above, Front: 19x8.5 6x115 with a +40mm offset, Rear: 19x10 6x115 with a +47mm offset). I would love to get 285's on the back, but don't want to shoot myself in the foot.
Any advice? Will 285's fit with a stock ride height without rub.
AAIIIC
07-14-11, 10:27 PM
At stock ride height I would say yes. Plan on running some decent negative camber.
rand49er
07-14-11, 11:44 PM
These Bridgestone Potenza RE970AS tires might work: http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=147
Since I don't need A/S, I'm looking at the Michelin Pilot Super Sport in 245/40ZR19 (front) and 275/35ZR19 (rear), 26.7" dia and 26.6" dia, respectively.
tony tone
07-15-11, 03:52 PM
Hey guys,
i run 285s on 10.5 rear tucking, but my forged wheel has a very aggressive offset. from what i've seen thread after thread these lineas aren't exactly offset friendly... meaning many have posted 275s rubbing lowered or OEM height.
JSR
07-15-11, 07:54 PM
I currently run 275's on my Corsa's at stock ride height with no rub. I plan to go to a 285 and lower it 1" (GC). Taking a look in there I may have to roll the inside of the fender but it should clear. Any lower than 285 and I'd say its a gamble.
WesH8398
07-18-11, 10:31 AM
Do you already have offset trailing arms installed? If not, I'm surprised. Take some aggressive corners with your radio off and windows up; I bet if you're on OEM trailing arms, they're rubbing on the inner wheel lip.
As for lowering, I think you'll definitely need to roll the fenders to put 285's back there. My 275's are a bit cut up from hitting my fender lip at the 2 o'clock (pass side) and 10 o'clock (driver side) positions. It was really bad with the drop from h&r springs, but even with them shimmed up to result in about a good inch total drop, they still hit the fender lips on big, sudden bumps/dips.
rand49er
07-18-11, 02:43 PM
^^^ Good info.
