: 2000 Cadillac Catera Transmission Oil & Filter
02-15-11, 05:41 PM
Has any of my fellow cadillackians done there own Transmission fluid/filter exchange?
If so how much fluid do you have to put in the pan before re-closing it?
Thanx in advance
02-15-11, 06:52 PM
the transmission is a "fill untill" there is a fitting on theside you remove, then fill.. untill it overfills. I belive it is around 8 quarts.. I belive you have to run the car.. its kinda a pain.. you have to have the special type seringe to fill the tranny. there was a recent post on here about it.. look through the posts..
02-16-11, 05:14 PM
I just used a siphon pump / hand held pump with the passenger side of the car jacked up a little where I could hold my hand to the hose going into pan bolt opening. I then refilled it with fluid until it started to come out slowly.
02-16-11, 06:22 PM
thanks guys it might be worth just letting the dealer do it. When is it recommended to do 125k?
02-18-11, 06:16 PM
i replaced mine after I bought the car with 121K and I didnt have any issues. But it was clear it had been serviced before.
02-20-11, 09:52 AM
